Crank Timing
4 replies to this topic
  • smithjeb
Posted October 04, 2009 - 04:30 PM
Newbie here. Did search but can't find the answer here.
I am adjusting the valves. Look through the timing hole to crank and there is 3 marks " I I I " - which one is TDC?. If I line it up on the 3rd mark then the cams are in the correct place (alignment dots at 180 degrees flat with top of case -just like in the manual). If I line it up with the center mark cams are not in correct location - slightly off.
2008 YZ450F - any guidance here ? Not sure why there are three marks, manual only shows one ?
Thanks for your help.
  • KJ790
Posted October 04, 2009 - 04:46 PM
Most YZ's have an 'H' and then an 'I'. You want to line it up with the 'I' in this case, which I guess would be the third line.
  • husqy360
Posted October 04, 2009 - 05:40 PM
screw driver in the spark plug hole.
Posted October 04, 2009 - 06:45 PM
Look more closely. The first two, from left to right, are joined with a horizontal bar, forming the previously mentioned "H". The third vertical line is the "I", and the TDC mark.
  • smithjeb
Posted October 04, 2009 - 07:00 PM
Perfect, thanks. This makes sense. Thank you for the responses - excellent to have a place to come to when taking on late night projects :busted:
  • Hot  50 replies
  • Hot  30 replies
  • Hot  113 replies
  • 10 replies
