greetings, neil here. been a lurker for a while as i read (tried to) all the old posts. then signed up yesterday. i noticed on another forum, mention that there was some discussion of increasing the i.d. of the oil feed tube to the top end as a cure for cam/rocker wear/failures. i don't see it being ness if your pump is in good shape and the hard line isn't pinched or plugged in some way. i didn't see anything in the archives either. anyone care to comment?? i am reassembling my XR600R with a new jug, valves, hotcam stage1, port and polish, oil cooler and could easily fab a new hard line.
also, i understand that the HotCams stage1 cam is designed to work with stock rockers and springs. i asked hotcams about using Kibblewhite springs with their stage1 cam and here is there answer:
"We designed that cam to work with stock valve springs. If you have other engine mods done and are needing to use aftermarket/stiffer springs that is fine, just be sure to check and adjust the valve lash accordingly. Also this may cause premature wear on the cam, I can not confirm this since we did not do any testing with aftermarket springs with the cam."
so i guess running non stock springs would be detrimental to cam life... anyone have any success using aftermarket springs with the stage1 hotcams? i know there have been posts indicating early failure.
thanx
neil
