frame change or not
4 replies to this topic
  • chuckar
Posted October 03, 2009 - 10:20 PM
i have 2003 YZ450F i ride desert and am going to race D37 scrambles in 2010 would it be worth it to change to a 2006+ frame not sure it would make that much difference since i run a desert tank
alot of people talk about getting a 2006+ YZ for the light weight frame will this help me or just change my CG on a bike i am already use to riding
  • JJRace
Posted October 03, 2009 - 11:00 PM
it is a total new motor in 06. Dont believe the previous years swap. Ask gray for sure, but I highly doubt it.
  • mikedabike
Posted October 04, 2009 - 01:44 AM
Too much stuff to change over. You would be better off selling the 03 and buying a 06+. The newer bikes are not any lighter because of the aluminum frame. They just handle better because of the more centralized and lower center of gravity.
  • chuckar
Posted October 04, 2009 - 07:21 AM
i will not be selling the '03 for awhile, is still in new shape(guy hurt himself after buying it new and doing sup. race tec forks and feal rear shock and spring, des tank, sdg seat and break away levers) when i got it the bike had very little boot wear on the frame
so when i wear it out i'll get a 2006+ then
Posted October 04, 2009 - 08:23 AM
The frame can be swapped, but it's not exactly a straight up, bolt together operation. Your current tank, seat, air box, and none of your current plastics will fit, either.
One of the biggest technical problems concerns where to put the oil. The '06 frame has no oil tank in it, which means a fabricated external tank or a wet sump conversion, which is out of the question for a desert bike.
  • 9 replies
  • 10 replies
  • Hot  36 replies
  • Hot  113 replies
