OIL LEAK
4 replies to this topic
  • GNCCYZ400
Posted April 26, 2000 - 06:23 PM
Has any-one had problems with the countershaft seal leaking. I've have replaced it twice and it's leaking agian. I have a 98 400.
Thanks,
JEff
  • Clark_Mason
Posted May 13, 2000 - 06:07 AM
If you run your chain too tight it will cause premature failure of this seal.
Clark
  • Matt_Porritt
Posted May 14, 2000 - 01:34 AM
Did you turn the bush around?
I found mine wearing on the bush.
Also check the orings on the bush.
**Ride it like you Stole it!**
Matt Porritt
99 YZ400F
Rubber Chicken Racing
  • GNCCYZ400
Posted May 15, 2000 - 05:57 PM
Clark
I am running it on the tight side, I'm running a sidewinder o-ring w/ stainless rear spk. and if i run it to yamaha specs it "slaps" pretty bad. I'll give it another shot and see if it helps.
Thanks,
Jeff
  • Bill
Posted May 24, 2000 - 12:23 PM
I told you, your chain is to tight.......
Bill
86TT225, 98CR80, 99WR, WR timing, throttle stop trimmed, air box lid removed, White Bros head pipe, silencer and air filter. Odometer and headlight removed. Moose hand and mud guards. YZ stock tank and IMS seat/brick.
  • 10 replies
  • 0 replies
  • Hot  113 replies
