hissing sound with the radiator...
5 replies to this topic
  • Daaaan
Posted October 01, 2009 - 03:25 AM
Is it because i have a very small crack in the radiator that i hear a rythmic hissing sound, about every 1/3 of a second? I have to mention that i loose about a tablespoon of coolant every day i go out, so it's not that big a crack...
Or is it something with the radiator cap, maybe it can't hold the pressure properly?
  • TX-SANDMAN
Posted October 01, 2009 - 06:21 PM
the cap may be a different issue. to fix a small leak I would pick up some Bars Leak from the auto parts store and use as directed.
They maybe able to test your cap too.
  • Daaaan
Posted October 01, 2009 - 10:44 PM
I suppose "Bars Leak" is some sort of high-temperature adhesive used to fix holes in aluminium? Sorry, i am from Romania...we don't have that brand of adhesive here.
Regarding your suggestion that they may be able to test the cap...well...I think mentioning my location is enough :busted: :banana:
So...the cap can be an issue if it doesn't seal the radiator properly? Can that valve on top be damaged?
  • Pooley
Posted October 06, 2009 - 07:33 AM
Some high temperature silicone should be able to plug up the small leak.
Because it is a continual, rhythmic sound, I would guess it is just the pressure put out by the water pump as the vanes on the impeller spin, creating a tiny surge in pressure, causing a bit to squirt out of the crack and vaporize on hot metal.
  • Daaaan
Posted October 06, 2009 - 10:56 PM
Best answer so far, in my oppinion... :busted:
Would there be any damage to the water pump or to anything else if i run the engine like this, or is the adhesive / silicone mandatory? The water loss after 2-3 hours of engine running is about 1 tablespoon...
  • ww44wrf450f
Posted October 07, 2009 - 05:40 AM
You need to find an additive for your radiator to stop leaks (auto parts store), you just pour it in, but you probably only need to add a little of it? You are not leaking very much fluid, drive it like it is, but pay close attention to it. Remember a bad crash can take out a rad, wait untill you really need to have it fixed or replaced!! Take the plastic shrouds off and go for a ride and see if you can find where the leak is?
http://www.barsproducts.com/C16_R6.htm
http://www.amazon.co...duct/B000AME522
