miss-shifts on 09
6 replies to this topic
  • seven10
Posted September 29, 2009 - 11:51 AM
Hey everyone I have a 09 and I'm having a huge problems with missing shifts (when I up-shift it gets caught in between gears) I have never had this problem on any other bike I've owned so I'm thinking I can throw out rider error, and I always keep fresh oil in the bike so I don't know what else it could be...Is anyone else having this problem!?
  • husqy360
Posted September 29, 2009 - 06:12 PM
you could try adjusting the gear shifter.
  • YamaLink
Posted September 29, 2009 - 06:59 PM
Does it mis-shift when you shift without the clutch? If you always shift without the clutch and it's obviously still doing it, then maybe move your shift lever down a notch. If you do shift with the clutch, is your clutch adjusted properly?
  • mikedabike
Posted September 29, 2009 - 07:32 PM
Is this your 1st Yamaha? I must say my Yamahas have never shifted as well as Honda's I had. I don't have enough experience on other brands to comment on them. I minimize the issue by making sure the shifter is adjusted perfect for me and always try to make sure my shifts are firm and deliberate.
  • Sider_steve
Posted September 29, 2009 - 07:40 PM
Is your shift lever tight on the shaft?
The bolt holding the shifter has a tendency to come loose.
  • seven10
Posted September 30, 2009 - 11:35 AM
yeah this is my first yamaha 450 i had a few yz250f and never had a problem, and yes my shift lever is adjusted the same as i would have it on any other bike (even when the footpeg) and I'll check right now too see how tight it is
  • Jim813
Posted September 30, 2009 - 07:05 PM
Some Yamaha shifters have a tendency to slide towards the motor, causing the shifter to catch on the ignition cover.
  • Hot  33 replies
  • Hot  28 replies
  • Hot  47 replies
