Help with 2009 YZ 450
4 replies to this topic
  • Raider23
Posted September 29, 2009 - 08:36 AM
I think I have a crank going. It pings just about everytime I shift down and sometimes when I shift up. What do you think?
Posted September 29, 2009 - 08:57 AM
I think I have no idea what you're saying. "Pinging" is the term usually used for spark knock, caused by inadequate octane number. It typically happens under a load at low rpm.
What is it that you hear, and when?
  • Raider23
Posted September 29, 2009 - 09:07 AM
I know it has nothing to do with detonation as a result of low octane. It sounds like someone hit a anval with a ballpeen hammer when I shift down and sometimes when I shift up. It also does it once in awhile when I rear break hard into a corner, if I did not get the clutch pulled in quickly.
  • davbrucas
Posted September 29, 2009 - 10:45 AM
So it only does it when there is a load on the engine correct? When you pull the clutch in and downshift it doesnt do it? Sounds more like chain/rearend issues. Or could be one of the gears on the right side...just pull the cover off the clutch side and pull the basket out and take a look.
  • Raider23
Posted September 29, 2009 - 01:22 PM
thanks guys I will look into it.
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • Hot  50 replies
  • 10 replies
