Wierd clutch problem????
3 replies to this topic
  • StPeters21
Posted September 28, 2009 - 06:10 PM
I have a 2006 YZ450. I have replace the entire clutch(Barnett carbon fiber), inner basket, outer basket, Stopper lever, and boss. I have an inconsistant problem. The clutch just doesn't seem to disengage. I just don't know where to look from here??? Unless it could be the actuator arm or push rod, I just don't have a clue at this point?
Thanks for your help. :busted:
  • StPeters21
Posted September 30, 2009 - 05:53 AM
after all the help I got???
I figured out what it was. The barnett clutch will not work with the synthetic oil. The clutch plates are sticking to the steels and not letting them spin. Anyway I have to get another clutch or change oil. I've ran amsoil from day 1 so...... Guess it's the clutch that's going.
  • BC3
Posted September 30, 2009 - 07:08 PM
[COLOR="Blue"]I haven't been on this forum for awhile so I had to read what you found if anything.......Funny thing is I had the same problem years ago with my BSA 500 (B50MX) seems I used Caster bean oil in the engine and didn't realize it lubed the clutch to and the same thing happened...hahaha glad you figured it out...[/COLOR]:busted:
Posted September 30, 2009 - 07:58 PM
It's not the oil, it's the plates, although they may be sensitive to the oil. Keep the trick hardware and substitute a set of OEM plates. You should be fine.
It's off topic, but the primary case oil in the B50, as with virtually every British bike of the day, was a separate oil supply, and did not come from the engine, unless there was a significant leak at the left of the crank. The clutch, technically, was considered a dry clutch. The oil was there for the chain only, and the clutch was "oil tolerant", but not expected to be very wet.
The bike, like all others of its kind, had a dry sump engine oil supply, and two separate oil supplies for the chain case and transmission. However, as you say, castor is HIGHLY unsuitable for any clutch.
Motocross
  • Hot  491 replies
  • Hot  50 replies
  • 9 replies
  • Hot  36 replies
