Just bought a 07 WR 450
13 replies to this topic
  • yamazuki10
Posted September 28, 2009 - 05:14 AM
So I finally got the bike I have been feening for for the past 3 years. After 3 DRZs,a KTM, and a WR 400, I finally have it. What now? It is already very hooked up, FMF Ti, AIS been removed, gray wire done, YZ throttle stop done, and armored up for the single track. My question is, what's up with the 2 oil dip sticks? One kinda on the side where a lot of dip sticks are and then there's one on the front of the motor kinda by the header? I plan on running Yamalube 10W-40, any other reccomendations? Any other quirks/issues with this bike? I read the FAQ and I had a WR 400, I loved that bike but was a PITA to start, and now I have the magic button with more power.:busted:
  • OUTERLIMITS
Posted September 28, 2009 - 06:00 AM
Just one dipstick. The one on the side is where you fill only.
Very few quirks with this bike. Sounds like you may have it jetted correctly in which case you are way ahead of the curve and the bike will start pretty easily. Oil is kind of a personal thing and dependent on temperature etc. I run 20w-50 of various brands. As to armor, the main thing on this bike being radiator protection. If you have that covered great, if not, there are some good brands out there. I have Unibikers and they have saved the same radiator twice where just the screen in front got a little warped (due to the bike landing on a rock right where the shroud mounts to the guard, but the cage around the radiator stayed perfectly straight.
  • yamazuki10
Posted September 28, 2009 - 06:27 AM
Thanks for your input. But why do both have dipsticks? Do I check the more forward one and just fill the one on the side? What's the capacity, about 2 qts?
  • Wrfrk
Posted September 28, 2009 - 06:43 AM
There should only be one dipstick, that being on the front of the motor. If you have a dipstick on the side where you are to put in the oil, that's something the previous owner did. The one on the side is redundant and really would not be accurate anyhow...
  • OUTERLIMITS
Posted September 28, 2009 - 07:06 AM
Exactly and as was mentioned above, the 2nd dipstick was probably added by the previous owner. I would not use that for any measurements. As far as capacity, the owners manual is very accurrate (1.06 qt with a filter change). That works out to about 34 oz. Make sure to open both filler and dipstick plugs when draining else you won't get it all out. I normally add a quart, run the engine a minute or two, shut it down and slowly add another 2-4 ounces until I'm on the high end of the dip stick markings. Make sure the bike is level.
  • yamazuki10
Posted September 28, 2009 - 07:12 AM
Thanks guys, I did'nt realize it held so little oil. Yeah the dip stick on the side is chrome, I know go figure. Why would you put chrome anything on a dirtbike? Unfortunatley I did'nt get an owners manual, but I'll buy a Haynes I guess.
  • OUTERLIMITS
Posted September 28, 2009 - 07:25 AM
The Yamaha owners manual is also a service manual and is very good. I downloaded an online version that I use more often than my hard copy. Check at the top in the stickies as I think that is where I originally got it. Forget the Haynes, not needed.
Can anyone confirm where this is located? It's been a while for me and I've forgotten where it was located.
  • 123BigcoopDawg576
Posted September 28, 2009 - 10:05 AM
Here you go :busted:
http://www.yamahaown...ook.com.au/?r=0
  • KennyMc
Posted September 28, 2009 - 10:42 AM
Rember their 2 drain plugs. On on the side by the shifter and 1 under the center of the motor.:busted:
  • yamazuki10
Posted September 29, 2009 - 04:02 AM
Thanks, good to know.
  • ohioryder
Posted September 29, 2009 - 10:09 AM
Are you referring to the inspection plugs? Because there is only 1 "drain" plug on the shifter side, one on the transmission side, and the bottom oil filter bolt.
  • KennyMc
Posted September 29, 2009 - 10:36 AM
I was referring to the fact that there are 2 drain plugs. 1 (next to shifter) + 1 (under the motor) = 2.
  • ohioryder
Posted September 30, 2009 - 06:19 AM
HaHa...I need to start getting more sleep :busted: I completely misread that!
  • KennyMc
Posted September 30, 2009 - 06:44 AM
HaHa...I need to start getting more sleep :banana: I completely misread that!
Checking my own spelling before I hit post might be a good thing as well:bonk: :busted:
