stripped head on oil drain bolt help!!!!!!!!!!!!
10 replies to this topic
  • bakeyz426f
Posted September 27, 2009 - 04:14 PM
the wr426f i just bought has a stripped head on the oil drain bolt. it is a 12mm socket and i tried hammering on a 11mm and when i tried turing it the bolt stripped again. what can i do to get it off??? i was thinking about jb welding a socket to it. any easier way?:busted: :banana: why does every used bike i buy have to have a sripped oil drain bolt :banana: :busted:
  • JimL
Posted September 27, 2009 - 05:45 PM
Try vise grips or a bolt removal tool from sears. then replace it with a magnetic drain plug sold here on thumpertalk.
  • panaman
Posted September 28, 2009 - 04:14 AM
try using one of these gator sockets
http://www.endeavorproducts.com/
  • bakeyz426f
Posted September 28, 2009 - 08:08 AM
do those work on completely rounded bolts? mine is a circle pretty much.
  • panaman
Posted September 28, 2009 - 10:02 AM
well... they are pretty cheap to buy... only way to find out is to try it....
  • kiebong
Orite mate. just had the same problem with my brothers bike. I lay the bike on its side. Hammered a smaller socket on just like you did. Then removed it with an 'Impact Driver' and a hammer. Do you know what i mean?
  • bakeyz426f
Posted September 28, 2009 - 02:34 PM
thanks for the help guys i got it off. i used an irwin damaged socket kit. i went and bought a sears kit too but when i got home i dropped the pieces everywhere in the garage opening it. i looked every where and couldnt find the one i needed. so i went to orielys and bought the irwin kit. i got the oil changed. i used synthetic lucus motorcycle oil 20w 50. is it normal for the oil to have to go in very gradually when pouring? it took abount 15 -20 minutes for the bike to soak up 1.8 quarts of it???????
  • panaman
Posted September 29, 2009 - 04:21 AM
i don't have a 426... but damn... 1.8 quarts of oil?? you sure thats the correct amount?
sounds like alot to me.... heck my DRZ only takes 1700ML
the newer wr450's take 1000ML
  • bakeyz426f
Posted September 29, 2009 - 07:38 AM
i thought it said 1.8 q
  • jayh300
Posted September 29, 2009 - 08:14 AM
my old yz400f took 1.6 or 1.8 don't remember for sure. alot more than my wr takes...
  • bakeyz426f
Posted September 29, 2009 - 08:27 AM
it looks full when i checked it. just right i think so i should be good.
