Flywheel installation question
3 replies to this topic
  • e30M3
Posted September 26, 2009 - 07:26 PM
So I just put the offroad flywheel into my '09. Everything went easy, almost too easy. My question is it seemed to take much more force to pull the old flywheel off than the 40ft pounds of torque it took to put it on. After searching I don't see anything that says to "press" the new one on (not in the factory instruction either).
Just want to make sure I didn't miss a step.
I do have a "once used" flywheel puller for an '09 YZ450 (and CRFs) if anyone is looking for a good deal:thumbsup:
  • Sider_steve
Posted September 26, 2009 - 07:30 PM
They go back on pretty easy.
No need to press it on,just line up the the slot with the key and bolt it back on.
  • e30M3
Posted September 26, 2009 - 07:35 PM
That's what I did, thanks. Everything seemed so easy just wanted to make sure I wasn't missing something.
Know I just need to do the ball bearing mod the the oil filter bolt. And yes, for the fifth time, you can find the bearings at a bicycle shop:smirk:
Posted September 26, 2009 - 07:44 PM
That's the way tapered shafts work. The flywheel "wedges" onto the shaft, and binds there. It requires very little clamping force on the part of the nut to hold it from rotating, and even the key does little more than put it in the right location to begin with.
  • Hot  38 replies
  • Hot  30 replies
  • Hot  28 replies
