MAX HP on a 400CC DRZ?
34 replies to this topic
  • BONESTOCK
Posted 26 September 2009 - 06:27 PM
Just curious on this. Been pondering it lately.
  • Rock Monster
Posted 26 September 2009 - 06:29 PM
Last I heard it was 60hp!:ride:
  • iowaBClivewire
Posted 26 September 2009 - 06:30 PM
  • mgw24
Posted 26 September 2009 - 06:31 PM
I think that's bored and stroked though-
I'm also curious what FCR/3x3/Exhaust/cams will do. Any other mods I'm missing for stock displacement?
  • iowaBClivewire
Posted 26 September 2009 - 06:53 PM
need more info
like what cams and what pipe
I can make a good guess with the added info
eddie - bronco - willy can tell you better than I can
  • chooken
Posted 26 September 2009 - 08:01 PM
before you go for big horse power , consider how to make the bike hook up .
you can have it all but if you cant get traction it defeats the purpose IMO .
  • knockout
Posted 26 September 2009 - 09:29 PM
I dont see it being much higher than 45. Add the E base gasket, some porting and cam timing, even with that i'd still guess with the 398cc's you're limited to about 47ish rear wheel horsepower. And thats probably rather optimistic.
  • Goebz
Posted 26 September 2009 - 09:37 PM
You gotta bore and stroke for big HP.
If not you cant expect to hit 50, on run 61 of Eddie's he's on;y getting 41 with FCR jetting and pipe (Akro).
Guessing with valves, and cams you could get another 2-3, Yosh pipe add 2 more. 45 or 47 would be it.
Eddie credits the crank with 4-5 hp.
its tough to decipher what each part will do b/c if you want to go Big Bore and Stroker you need fcr 41 instead of 39. Then theres all Eddies head work.
  • mgw24
Posted 26 September 2009 - 09:50 PM
More of an issue with an S or K, SM not so much on pavement I would think. I understand what you are getting at though: on Dirt- the best dollar I have spent on my KX has been with the suspension and tires. I guess I'm not a good enough "street" rider to see the difference with my DR-Z SM. At stock settings- the DR-Z SM handles so much better stock than my ZX-6 ever did. But- apples to oranges.
  • iowaBClivewire
Posted 26 September 2009 - 11:12 PM
I just wate for eddie to see this thread
  • BONESTOCK
Posted 27 September 2009 - 12:38 AM
I know you can reach 60hp with bore and stroke from SSW. If i rode on the street only I would love to have it. But I ride offroad 95% of the time and there is no need for 70hp where I ride. Im just curious to what a well build 400 (398) would do thats all. MRD pipe FCRMX Cams etc etc. I was guessing 45 or so and to me that plenty.
  • Eddie Sisneros
Posted 27 September 2009 - 04:14 AM
depends on what fuel you are willing to run.
low 40's pretty easy.
  • Smias
Posted 27 September 2009 - 04:24 AM
  • KillerDwarf
Posted 27 September 2009 - 05:12 AM
I installed the yosh ti, so might have added another hp, the FMF is basically an E exhaust. I also put the stock S cdi back on. 3600 miles since Eddie's magic and bike is still running great!
  • rigga
Posted 27 September 2009 - 01:49 PM
just got back into drz ownership.... allbeit fitted into a ccm 404.... but when i had a E spec drz last with a full fmf system,powerbomb header and Q silencer it made just over 45hp......got a dyno print out somewhere on the web if i can find it
Found it amongst pics of the drz.....
http://gallery43749....et/c114298.html
  • iowaBClivewire
Posted 27 September 2009 - 03:08 PM
that is the key to your 45hp
you had the 39mm FCR carb and little better cams from the factroy -- so you ware making bamn near 39HP out of the box
take the normal SM with the 36mm carb stock cams and just a rejet and pipe your looking under 35hp
  • rigga
Posted 27 September 2009 - 03:29 PM
Agreed the E spec will be more powerfull than the S ... pretty well gospel knowledge on here by now,thought the op's question related to capacity and power though regardless of cams and carb set up.....
  • BONESTOCK
Posted 27 September 2009 - 06:22 PM
So all I need to make my S engine an E engine is
1. FCR 39mm
2. E model Cams
3. Base Gasket
And to make the low 40s hp I will need an exhaust. I have stock S model exhuast. I really like the FMF Q4 because it is quiet.
  • donny662
Posted 27 September 2009 - 08:36 PM
The E also has a different exhaust with a slightly larger head pipe diameter than the S/SM. (IIRC)
  • BONESTOCK
Posted 27 September 2009 - 08:41 PM
You are correct. I will get a Standard MRD probably.
