I have a 07 S. I have done the 3x3 mod. with a JD jet kit 160 main 25 pilot blue needle on the fourth clip, opened up the end cap on the muffler, auto decomp removed, MCCT, 14 tooth front sprocket, and I just put on a Clark 3.9. My bike has kind of been a dog since day one I must say I have been a little dissapointed. I did not really notice any power gain after the 3x3 just worse mpg. my problem is not only the what I think is lack of power but it sound like my piston is going to come up and go through my tank. It is not all the time just when i throttle into it. It started in just the high gears and seems to be getting worse and will now do it in the lower gears. It runs fine crusing around town but if i get into it a little bit the sound sends chills up my spine. I have ran 92 octane in it since day one. PLEASE HELP!!!
scary sounds
Started by buckhuntr, Sep 26 2009 03:34 PM
11 replies to this topic
Posted 26 September 2009 - 03:34 PM
Posted 26 September 2009 - 06:40 PM
your runing to ritch for the pipe modds you have
so now you have a build up of carbon in the combution camber
this has razed the comp. making detanation do loud you can hear it
ether that or ---- your cam timing is off one tooth and the piston is hitting the valve
Posted 26 September 2009 - 06:45 PM
Have you checked your valves lately, cam caps for tightness, adjusted the MCCT, checked your drive chain for tightness, stator/starter bolts and primary gear for correct tightness? My bike just started pinging after I did the 3x3 and rejet but only in top gear, under light load and heavy throttle. Hope some one chimes in soon, your problem and mine might be realted. :banghead:
Posted 26 September 2009 - 06:50 PM
I fixed all my detnation issues with a set of "E" cams that have more over-lap than the S/SM cams
this loweres the stadick comp.
Posted 26 September 2009 - 06:53 PM
I was thinking of going back to the stock jetting and seeing what that did.
Posted 26 September 2009 - 06:55 PM
I would look at can timing furst
get a better pipe with cams it will really help your lack of HP
Posted 27 September 2009 - 08:35 AM
what will stock jetting due with the 3x3 hole cut out and my exhaust tip opened up. I would love cams and a new pipe just not right now.
Posted 27 September 2009 - 08:47 PM
Stock jetting is said to be lean for the stock engine. Opening up the airbox theoretically leans out the mixture even more, so I would suspect that going back to the stock jets would be a bad idea.
Checking the cam timing is not hard: take off the head cover, set the engine to top dead center (TDC), and check if the arrows on the cam gears line up (I believe).
