OWEN THE FLAPJACK said:
disc is standard size wavy by the way.
was thinking of a big disc but thought that this may not help massivily as its still pad contact surface that counts
ACTUALLY its leverage that counts! thats why the larger diameter of a rotor moves the clamping force of the caliper outwards thus making it easier to stop with less effort. further the rotor is out from center rotating point makes the same amount of clamping force do more. The wavy disc's werent really designed for surface area but to move air thru there and have it help cool the pads and not overheat, a solid rotor actually gives more constant pad to rotor surface area but the wavys cool so much more that they work as good as a full rotor.
i would get a SS front line, and if that doesnt show some more power up front then maybe its possible your master cylinder is a tad wore out and needs replaced, TONS of front brake MC's on ebay too.
