2003 Wr450f Flywheel won't come off with tool
5 replies to this topic
  • Andrejs2112
Posted September 23, 2009 - 05:42 PM
My flywheel threads are junk so I can't get the rotor removal tool threaded on to remove the flywheel the proper way. The flywheel is junk so ruining it isn't a problem. I was going to try a 3 arm puller, but I'm not sure the arms have enough to grab onto and hold. Anybody have other ideas?
  • mrlopez
Posted September 24, 2009 - 08:22 AM
Maybe you can retread it to the next size
  • 123BigcoopDawg576
Posted September 24, 2009 - 08:51 AM
The 3 arm puller wont work...
If you have a welder, throw a few tac welds on the tool and fly wheel :busted:
  • GCannon
Posted September 24, 2009 - 09:03 AM
Drill and tap two or three holes in the flywheel and use a bolt grip puller like you would use on a steering wheel or a harmonic balancer???
  • Andrejs2112
Posted September 24, 2009 - 01:16 PM
I got a 4" puller today. I put it on, heated the flywheel a bit, got a hammer and tapped and tightened, tapped and tightened, etc, etc. Came off without a pop or much resistance. Didn't have to hit it very hard at all. Just firm taps. Thanks for all of the replies.
  • Andrejs2112
Posted September 24, 2009 - 01:20 PM
Now I need to get out all of the copper and plastic bits out of the bottom of the crankcase. How dangerous is it to have a few of those bits in there?
