Getting ready to do a kickstart conversion on my xr650L and got a complete gasket kit. I am only disassembling the engine, swapping the countershaft and re-assembling. Can/should any of the existing gaskets be re-used? I figure the fiber ones should be replaced, but what about the metal ones? The gasket kit came with a metal replacement for the cylinder head cover and one for the cylinder/head. Am I better off leaving the original metal ones in place or should I swap them out for new metal ones? Also the cylinder/head metal gasket is actually three gaskets crimped together. Why 3? Are you supposed to use all three? They don't look like they are supposed to be separated. Also any suggestions on using anything on the gaskets such as sealer or just put them on dry?
