no compression, cant kick start my 2004 kx250f only push start it
3 replies to this topic
  • kasper37
Posted September 22, 2009 - 04:43 PM
I just bought a 2004 kx250f. He said the engine/valves were all just rebuilt. It was a little hard to kick start, took some getting use to after riding a 2 stroke. But when i would get it top dead center then kick it usually worked fine. But about a 1 hour/1 1/2 into my first time out riding it it was getting hard to start and had to push start it. Alot of times when I slowed down it would die. But compression wasn't that bad and road fine when it was going. After I got home and the next weekend I was getting ready to go ride I wanted to make sure it would start and there was no compression. Now I can't kick start it, only push start it. I checked everything but cannot figure out what it is. When we kicked no air sucked in the exhuast and no air blew out of the carb. took oil fill plug out kicked it with thumb over hole to see if there was blow by air from the piston and there was not excessive pressure. Carbs were cleaned out good. Disconnected air box from filter in case it wasnt gettin enough air. I called the guy i bought it from, told him whats up, he three wayed his mechanic, we went through all the same steps we checked. he called some buddies and they said that since the engine was rebuilt and i took it out it broke in the engine and now it set. So to do a valve adjustment/shim. Does that sound right ande what do i need to do to get back out riding? Regards chris.
  • the white stallion
Posted September 22, 2009 - 06:46 PM
Step#1:http://www.thumperta...ad.php?t=335909
Step #2:http://www.thumperta...ad.php?t=461811
He could have replaced the valves with out cutting the seats.
Do you know how old that piston is?
  • kasper37
Posted September 22, 2009 - 07:33 PM
he said it was all new..so i rode it about 3 hours
  • kasper37
Posted September 22, 2009 - 07:53 PM
thanks..that will help out alot and save me some $...alot of people say that after you have to shim your valves its going to keep happening...is that tru and do you think what he is saying about the new engine setting tru
2016 kx250f bogs when upshifting by Eric556
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
Unknown '08 gas/air issue by thopter_jr
Dirt Bike   Make / Model Specific   Kawasaki   KX250F
  • Hot  36 replies
Differences between the F and FX? by motoxpress
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  49 replies
2013 Kx250f wide range gearing by got2haveit909
Dirt Bike   Special Interest Forums   Dual-Sport/Adventure
  • 0 replies
Trouble selling bike? by Bwdeaton
  • Hot  44 replies
