Whats the best way to break in a rebuilt motor?
7 replies to this topic
  • kjwarren
Posted September 22, 2009 - 02:31 PM
Just got the top and bottom end rebuilt on my 02 426 whats the best way to break it in?
  • Beaz
Posted September 22, 2009 - 05:20 PM
Ive always taken it easy for about 5 minutes let it cool checked nuts and bolts then rode it at my normal pace
  • delmas
Posted September 22, 2009 - 05:22 PM
http://www.mototuneu..._in_secrets.htm
  • kjwarren
Posted September 22, 2009 - 07:34 PM
Anyone use this technique?
  • lluks252
Posted September 22, 2009 - 10:15 PM
My friend and I put a new wiseco piston on my '05 yz450f. All I did to break it in was, go riding for like 10-15 min 1/2 throttle. Let it cool down completely, check bolts like you said. Then, ride it for around 30-45 min 3/4 throttle. Let it cool down again. Then I went out and rode like normal.
  • mkporn
Posted September 23, 2009 - 07:53 AM
The way I break in every motor I do for someone i do the same way and have never had issue.....I tend to put it thru 3 heat cycles....
Put it together, start it up and let it idle and come to a good operating temp (hot to the touch on the head....Shut it down and put a wrench on everything to make sure everything is tight. Check fluid levels. Let it cool off.
Start it back up and come to temp...ride it around a couple minutes (no full throttle) 5-10 minutes of varing speed and throttle (do not hold at one speed or rpm for very long). Shut it off and cool, put a wrench on everything again (double check just for the heck of it and it gives you something to do while waiting for it to cool) check the fluid.
Now for the last step.....Ride it like you stole it.....:busted:
  • Wiz636
Posted September 23, 2009 - 08:44 AM
I fire it up and take it easy for just a couple minutes to make sure everything is working...then it's hammer time.
  • kjwarren
Posted September 23, 2009 - 01:02 PM
Thanks Guys
  • Hot  33 replies
  • Hot  79 replies
Motocross
  • Hot  491 replies
