I have a 1999 yz 400 that is basically stock. The problem occurs when the engine is at low rmps or idle and the throttle is opened quickly. The engine will die as if it is being starved. Also, when first starting the choke takes a while to work. I have adj. the valves, checked the TPS, used a 173 main jet, went up and down several clips on the needle, atc. Help would be appreciated.
Thanks
Nick
