hi all, im still new to this site and u all have been very good to me with info in the past so im thanking u all in advance anyways, i have a 94 xr 600 and a couple of days ago went to start her up and the kickstarter got stuck and nearly broke my ankle lol i thought ill put it in gear and roll her backwards (dont know why really) but it seemed to work and freed up the kickstarter but then after a few kicks it siezed up again my question is does anyone know what i've done and how i can fix it? many thanks again
94 xr600 kickstarter stuck
Started by spez778, Sep 19 2009 08:45 PM
8 replies to this topic
Posted 19 September 2009 - 08:45 PM
Posted 19 September 2009 - 09:01 PM
There are internal reasons for it to fail, but check that the footpeg mount isn't the problem. After countless impacts the footpeg mount bent back enough so the kick starter wedged in it pretty good.
Posted 19 September 2009 - 10:50 PM
thanks cleonard but thats not where its getting stuck it wont even start to kick down then when i put it in 1st gear and roll backwards its makes a grinding/whirring sound which cant be good but then it frees it up for a kick or two then seizes back up
Posted 20 September 2009 - 05:02 AM
Oh Boy! I'm sorry to be a bearer of bad news.... Sounds like you got a locked up piston mate!
Posted 20 September 2009 - 12:22 PM
oh ok i hope not i put a new set of rings thru about 6mths ago and all seemed well until now and only ridden about 10 times so how do i unlock it?
pull it apart again?
Posted 20 September 2009 - 12:45 PM
Remove the spark plug. Be sure to blow away the crud around the plug with compressed air before removing. Remove the plug from the LH side cover so that you can rotate the crankshaft with a socket wrench. Slowly rotate the crankshaft and see if two full revolutions can be made. If the engine locks up, rotate it in the opposite direction. If it locks up at the same spot, there is internal damage, dropped valve, broken piston are two possibilities. If the engine turns freely for several revolutions, remove the RH side cover and check for damage to the kickstart mechanism, idler gear or primary drive. I have also seen the symptoms your engine is displaying with a failed lower rod bearing/thrust bearing.
Posted 20 September 2009 - 01:13 PM
+1 on this well stated advice. It's time to start digging.
Posted 21 September 2009 - 01:39 AM
ok guys thanks for all the info ive got me shovel and im going digging i'll post my results later in the week cheers again
Posted 09 October 2009 - 08:36 PM
im back sorry to take so long other projects getting in the way :smirk: i had a look today and it seems that its not the kickstarter thats getting stuck its the cam it seems that the reverse decomp lobe is sticking and seizing the motor could this be the case and if so are there any answers to this problem? do i need a new cam assembly? when it sticks thats when this horrible wrirring /grinding noise starts until i wind the engine in gear backwards then it frees up then i try and kick it over a few times (wont start either by the way)then it jams up any help is appreciated cheers for now
