Stewart's 2010 450 up close
54 replies to this topic
Posted September 26, 2009 - 03:46 PM
#41
thats deff. not for a wideband its welded to the res. it wouldnt get a true reading.
It would if the probe passed all the way through into the gas stream. In truth, it would be accurate even if it didn't. It would just be somewhat slow responding.
  • Sider_steve
Posted September 26, 2009 - 04:03 PM
#42
Look closely at the bolt and you will see a slot for screw driver. Maybe it is attached to a metallic bellows that when said screw is turned in/out it moves the bellows thus adjusting the volume of the header. Simple way to change power characteristics. Cheers Bruce
I was leaning towards an adjustable resonator myself.
But I don't really know. Since the system on Js's bike seems to have another resonator in the loop section.
  • ProjectDIRT
Posted September 26, 2009 - 07:57 PM
#43
but if you noticed that nut is welded on to the res it almost looks as if the res could come off and it doesnt look big enough for a o2 sensor.
Posted September 26, 2009 - 08:02 PM
#44
Not for an O₂ sensor, no, but a gas analyzer, yes, particularly if it was a custom set up.
  • ProMed
Posted September 26, 2009 - 08:58 PM
#45
Not a crack. Look at the lower subframe mount. I bet Stewart wanted the subframe lower for better rider positioning so they cut it and rewelded it.
You'd be surprised how fast Pro Level guys tear up equipment. I've seen a few guys wear through graphics in a weekend racing super cross.
Compared to the test bike at Budd's Creek:
Bubba's bike:
Budds Creek test bike:
  • ZéPovinho
Posted September 26, 2009 - 10:17 PM
#46
:busted: two ressonators on the mid pipe? :banana:
Posted September 26, 2009 - 11:02 PM
#47
Nope. One is Stewart's bike with an Akro, resonator in the mid pipe, none on the header, and the other is a stocker, no resonator on the mid pipe, but one on the header.
  • Sider_steve
Posted September 26, 2009 - 11:48 PM
#48
You might want to check the pictures out in the first post of this thread 1 more time.
There is something in the headpipe and the midpipe area has an Akropovic.
At least the same shock with the added reservoir is in both pictures.
  • js7_yama
Posted September 27, 2009 - 12:25 AM
#49
James Stewart's Florida Ride with Fans on the 2010 YZ450F :busted:
http://www.redbullus...p=1242751077587
http://www.redbullus...7587&quality=hq
  • nephic
Posted September 27, 2009 - 01:35 PM
#50
wow, so much for worries about that bike in the whoops. Check out JS blitzing through that sand. I cannot wait to get a leg over one of these bikes.
  • FourtySixandTwo
Posted September 27, 2009 - 02:09 PM
#51
You sure gray? Look at photo 2 and 3 again. http://sozoamplifica...om/stewart.html
  • SoZo
Posted September 27, 2009 - 03:45 PM
#52
I can answer questions about the bike , I rode with him that day and took those pix standing right next to the bike...
John
  • FourtySixandTwo
Posted September 27, 2009 - 04:07 PM
#53
John
So did his exhaust system have two resonators on it? Picture 2 shows one that is just in front of the frame and picture 3 shows what appears to be another just behind the shock reservoir. Just curious is all. Thanks for the pics!!!
  • Sider_steve
Posted September 27, 2009 - 05:49 PM
#54
John
Is the bubble in the pipe right off the head a resonator or is it for some other use?
Like a place to plug in a probe for tuning the EFI?
  • SoZo
Posted September 29, 2009 - 04:21 PM
#55
Yes 2 Resonators, the one where the stock one is with a weird nut welded in and the one in the middle of the tornado part with a pipe connecting either side of the circle and that chamber in the middle.
  • Hot  36 replies
  • Hot  38 replies
  • Hot  50 replies
