WR450 Engine noise. Please diagnose. Youtube Vid Incl
31 replies to this topic
  • stev0
Posted September 20, 2009 - 01:15 PM
#21
I hope so. Id like to get the valves checked out too... maybe the shimms are worn.
  • Sider_steve
Posted September 20, 2009 - 01:27 PM
#22
Sounds like the bike is due for a good check up.
Check valve clearances and cam chain for stretch.
And the chain guides also the cam chain tensioner.
  • Krannie McKranface
Posted September 20, 2009 - 05:10 PM
#23
Yes, there is a gasket: it's the copper crush washer still on your cylinder.
  • stev0
Posted September 21, 2009 - 01:27 AM
#24
Update,
Cam cover off, bike at tdc...
something does look wrong...
:busted:
  • Butta
Posted September 21, 2009 - 08:03 AM
#25
Cam lobes are facing directly away from eachother.....that checks out....
What looks wrong, the alignment marks?
  • stev0
Posted September 21, 2009 - 08:54 AM
#26
The marks are suppose to be aligning @ Tdc. Cam chain is stretched.
I can probably change the chain myself, but I really dont feel like it. Should be going to the shop next monday...
Im already looking for a 2stroke replacement... ktm300 or CR/KX500 :busted:
  • Sider_steve
Posted September 21, 2009 - 09:31 AM
#27
The cam chain is fairly inexpensive.
You already have the top off,all that is left to do is get the flywheel and stator out of the way.
  • stev0
Posted September 21, 2009 - 09:59 AM
#28
To be honnest, I dont feel 100 percent comfortable in doing it a first time.
Originally I thought the cam jumped a tooth, so I moved the cam one tooth forward. The stroke was heavy and I realised something was not right. I had to open the head up again and put the the cam back in its original position. This is when I found out that the YZ - WR cam timing is slightly different and the intake cam is suppose to be flat rather then slightly tilted.
  • Sider_steve
Posted September 21, 2009 - 10:06 AM
#29
Did you get a good look at the cam chain guides(dampers).
  • stev0
Posted September 21, 2009 - 10:08 AM
#30
No I did not, should I be concerned ?
  • Sider_steve
Posted September 21, 2009 - 11:15 AM
#31
yes if your chain has that much play it may have worn or broken them.
  • stev0
Posted December 17, 2009 - 10:31 PM
#32
ended up being the big end... with a worn crank gear, I had to do a whole rebuild. replaced everything... valve's, crank, barrel, new piston and rings ect ect.
