how much oil 1.0 Liter or 1.2 Liter
16 replies to this topic
  • panaman
Posted September 18, 2009 - 11:29 AM
The book is a llittle confusing....
I am doing my first oil change... and I changed the oil filter...
do i put 1.0 liters or 1.2 liters in it?
  • 123BigcoopDawg576
Posted September 18, 2009 - 11:53 AM
1.0L w/ filter change :busted:
  • JSanfilippo
Posted September 18, 2009 - 01:06 PM
I don't even measure anymore.
I pour a quart. Run the motor for a couple of minutes. Check the stick. Then add if necessary.
  • panaman
Posted September 18, 2009 - 01:11 PM
exactly.... but why does it say 1.2L total
  • 123BigcoopDawg576
Posted September 18, 2009 - 01:14 PM
if you do a rebuild and its dry, you would need 1.2 but since your only changing the oil and replacing the filter, you will not get all the oil out so you will only need to put 1.0 L in.
Do take this the wrong way but why over think it. It clearly says that if you change the oil and replace the filter you need to put 1.0L right?
So...only put 1.0L :busted:
  • tribalbc
Posted September 18, 2009 - 05:08 PM
I don't even bother checking the stick. Give her a good draining and throw a litre in with a filter change and 950ml without.
Make sure you remove the dipstick when draining the oil tank :busted:
  • JSanfilippo
Posted September 18, 2009 - 05:26 PM
Why? Just removing the oil fill plug is enough to get the drains flowing good. I'll try it on the next oil change though.
  • tribalbc
Posted September 18, 2009 - 05:47 PM
I find it releases the vacuum on the oil tank alot better than the oil fill plug.
I'm sure the fill plug is fine as long as you get one or the other to release the vacuum.
  • 123BigcoopDawg576
Posted September 18, 2009 - 06:50 PM
Make sure you remove the dipstick when draining the oil tank :thumbsup:
Ditto :busted:
  • mrlopez
Posted September 19, 2009 - 09:03 AM
If you put a little to much oil wouldn't just make come out the bottom hose?
  • madbriuk
Posted September 25, 2009 - 03:58 AM
i put too much in and it cable out the overflow in my air filter i won't do that again lol
  • Wrfrk
Posted September 25, 2009 - 05:20 AM
Well I do things a little different then it sounds.... When I change my oil and filter I do put back in 1.2L and it ends up perfect. However before I change the oil I run the bike for 5minutes or so, then shut it down for 15 or so to let the oil settle back down. I then pull the fill plug and dip stick, after which I pull the right side drain plug and drain as much as possible, occasionally leaning the bike back and forth. Then I pull the oil filter and extract the remaining oil from that area before installing the new filter. Then, I pull the left side drain bolt and let it drain until there's no more than a few drips coming out. From that point I lean the bike back and forth to get the remaining oil out. That may seem excessive I suppose but I want the bad crap out, so from that point it does take more than 1L.....
  • tribalbc
Posted September 25, 2009 - 05:47 AM
I do the same process but only refill 1L. No matter how much you tilt and let it drain there will be oil left in there ( around 0.2L ) Ever done a complete drain and then pull the cases ? There's oil left in there.
So you are overfilling and are likely to see some oil in your airbox sooner or later.
  • 123BigcoopDawg576
Posted September 25, 2009 - 05:51 AM
Ignorance is bliss I suppose :busted:
  • SXP
Posted September 25, 2009 - 08:06 AM
So, what made this a "5 Star" thread?
  • 123BigcoopDawg576
Posted September 25, 2009 - 08:08 AM
LOL I was wondering the same thing :busted:
  • 123BigcoopDawg576
Posted September 26, 2009 - 12:30 PM
Just did an oil change and filter replacement and guess what...1.0L is what she took :busted:
