I'm thinking about using Synthetic Oil in my 426 for its obvious benefits. Has anyone tried synthetic oil and would you recommend it for a horsepower and protection gain? Just wondering.
Synthetic Oil
Started by Guest_Guest_*, Apr 03 2000 04:05 PM
11 replies to this topic
Posted 03 April 2000 - 04:05 PM
Posted 03 April 2000 - 06:24 PM
Quote
Posted 04 April 2000 - 01:24 AM
Quote
I use Castrol GPS (semi syn) and it is great.
Comes out alot cleaner than the **** Yamalube 4R which is a VERY low rated mineral.
Have had no clutch problems and I also supply about 4 other guys who ride 4st and use the stuff with good results.
**Ride it like you Stole it!**
Matt Porritt
99 YZ400F
Rubber Chicken Racing
Posted 04 April 2000 - 04:44 AM
I have switched to Modil 1 from YaMALUBE 4r. tHE 4R was broken down, black crap after 2 good long rides but the Mobil 1 has stood the test much better. I wold feel comfortable getting 3 good long rides with the Mobil 1. I can not tell a difference in power and there are no problems that it creates witht he clutch that I have seen. Also the oil filter is removable and cleanable no need to buy a new one unless it is damaged.
josh
josh
Posted 04 April 2000 - 05:45 AM
I'm going to Mobil 1 as well on my next oil change. The 15w50 is the one to use, as it has no energy conserving additives that would be bad for the clutch. I've heard of a lot of people using it with very good results. I think it offers superior lubrication as opposed to petroleum based oils, and seems to have no adverse effects. There has been many a debate on this issue, but IMHO Mobil 1 15w50 is good stuff.
Posted 04 April 2000 - 11:15 AM
JMB the 15/50 is what I am using and you are correct it is excellent oil. I recommend it very very highly after switching to it.
Posted 04 April 2000 - 11:43 AM
Quote
Posted 10 April 2000 - 09:59 PM
Although I am new on this list, my experience on the street has been......usually the bike manufactures design the clutch to hold up to stock power. In this case you might be OK to go with Synthetic oil. However DO NOT go back and forth between Synthetic and Dyno juice (petrol oil)!!! Synthetic has a different effect on the oil seals. If you change, stay with it. Personally in all my bikes I use Mobil Delvac 1300 super 15/40. This is a oil that was developed for big trucks, but also has a transmission/gear rating. It works great with no clutch problems. The best part about it is that it is cheap (locally it is $4.50 gal), so you can afford to change it often. Hope this helps.
Posted 12 April 2000 - 03:55 PM
Ive used Honda HP4 from the get go. Works great, no clutch slippage and I actually USE my clutch, against all advice in the mags.
Mike Hetrick
'00 426
'99 Ducati Monster
'73 Kawasaki H1
Mike Hetrick
'00 426
'99 Ducati Monster
'73 Kawasaki H1
Posted 13 April 2000 - 07:08 AM
I'll agree with Alex, I recommend you stick with the Yamalube for the clutch. I did a little too much fanning while riding with a fully synthetic and burned it black.
The dealer I ordered the Barnett clutch from claimed it wouldn't of burned had I used the Yamalube.
Tim
Utah Moto Adventures
www.utahmoto.com
Tim
www.utahmoto.com
Posted 13 April 2000 - 09:08 PM
That dealer was just trying to sell you Yamalube :-)
Yamalube is a good oil, but the dealer is mistaken.
Rich
Rich
Posted 13 April 2000 - 11:43 PM
Rich-
We can't buy a worse oil here in NZ than Yamalube. Its only a SG or something rated.
We pay $16nz ($8us) a liter for it and shitty car oils with the same raing are $10 for 4l ($5us)
I though it was **** ..
I don't use the clutch bugger all and after 2 rides it was BLACK!
Castrol GPS (semi syn)and 5 rides later its heaps better than the 4R.
Matt Porritt
99 YZ400F
Matt Porritt
99 YZ400F
