I changed the rear spring of my shock. I checked the shock bearings while I had it out of the bike. They seamed nice and tight with no play. After I put it back. I noticed if I try to move the shock it moves side ways. But I don't get any up and down movement. Is the side movement normal? Thanks Ben
Rear shock ply. Am I ok?
Started by Ben99R1, Sep 17 2009 06:57 PM
2 replies to this topic
Posted 17 September 2009 - 06:57 PM
Posted 18 September 2009 - 06:40 AM
u'll get a little radial play if u try to twist the spring...:thumbsup:
...make sure to get the preload/sag set correctly and back off the compression about 2-4 clicks from the stock setting...these have shocks have crazy rebound control and i'm only 1-2 clicks off of full soft for riding in the dirt.
:cheers:
:cheers:
