450 Exhaust Cam on WR426- Used Parts Availability?
11 replies to this topic
  • hazey123
Posted September 17, 2009 - 07:56 AM
I want to fit a 450 cam onto my 2002 WR426 primarily for the auto decomp. Most of what I read, talks about using the YZ450 cam and not the WR450 cam? Is this primarily due to availability of the former? Can I assume either will work but with a different powerband? Can someone explain the differences between the two. I plan on leaving the intake cam WR stock.
What are all the years that I can pull from if surfing the used parts (ebay) market? 03? 04?... I am trying to find one at a good price.
Thanks for the help.
  • mrlopez
Posted September 17, 2009 - 08:09 AM
I'm interested also since I have a 400 and would like to upgrade to 450 with electric start, since I have a set up
for Supermoto I need to start gathering info
  • 123BigcoopDawg576
Posted September 17, 2009 - 08:37 AM
I want to fit a 450 cam onto my 2002 WR426 primarily for the auto decomp. Can I assume either will work but with a different powerband
You can use either the WR or the YZ cam from 03-05 to the decomp mod.
The main difference is going to be the WR cam is "milder" than the YZ cam :busted:
  • GCannon
Posted September 17, 2009 - 09:20 AM
IMHO I think buying a used Cam is dangerous and if you must you should use the $$savings to buy two new buckets for the exaust cam so that you don't have an incompatibility issue with already worn parts that have become "familiar" with each other.
I could be wrong on this but isnt the new exhaust cam only $150.00 or less new?
There is useful information here that you may be interested in.
http://www.thumperta...5282&highlight=
  • 123BigcoopDawg576
Posted September 17, 2009 - 09:51 AM
The YZ cam is cheaper by 60 bucks...but it has also gone up its now 170 bucks
03-05 YZ Cam part number: 5TA-12180-00-00 - $170
03-05 WR Cam part number: 5TJ-12180-10-00 - $229
  • hazey123
Posted September 19, 2009 - 01:51 PM
What exactly does "milder" mean in reference to the WR vs. YZ. I ride mostly woods and need the low end, as it is currently very chuggable through tough stuff. I wouldn't want to loose that with a YZ exhaust cam.
Does the YZ cam just add more power across the powerband or does it actually change the profile? Thanks
  • byggd
Posted September 20, 2009 - 05:14 AM
There is no upgrade to e-start :busted:
  • byggd
Posted September 20, 2009 - 05:20 AM
With a WR cam there is a midrange “hit”. With a YZ cam the bike will pull longer and harder but the power delivery is more even.
  • pablo83
Posted September 20, 2009 - 05:59 AM
I have a used '03 WR450 cam in my '01 WR426 and have had no compatability issues. The bike is so much easier to start.
  • RichFZR-WR
Posted September 20, 2009 - 11:32 AM
Hi,does this mod help with hot start issue, cause thats the only issue i've got with my 426.
  • pablo83
Posted September 21, 2009 - 09:54 AM
The only thing it does is makes kick starting easier. So if you have to kick the bike 4 or 5 times before it will start it won't kill your leg for the rest of the trip.
I'd suggest cleanig your carb and checking the hot start mechanism to get y our bike running better.
  • hazey123
Posted September 23, 2009 - 01:55 PM
Does anyone know about the YFZ exhaust cam from Yamaha's quads. Is it the same power profile as the YZF dirt bike? Will the 04 YFZ model fit the same as the 03-04 YZF model?
