My old engine had developed a few issues so it was time for a replacement. I have been collecting parts for a while and I took all the best parts to come up with a replacement. The only parts I reused were the cam, valve cover, and cylinder after a fresh bore.
The engine started up first kick and I put about 250 miles on the bike last weekend. The engine ran great, but I noticed one thing that was not right. At idle it makes an occasional loud tick. The engine also misfires once when the sound occurs. I happens a bit more when you let off the throttle as the revs decrease.
Last night I got a few minutes to look at it and the noise appears to be coming from the head for sure. I'm hoping to get a bit more time to look over the next couple of days and I wondering what to look for. I'm thinking that it must be the decomp system engaging when it is not supposed to be. Then the loud tick noise would be the cam follower coming off the decomp cam and snapping closed. That would also explain the misfire which happens at the same moment. I have another cam to try, but I would like to try and figure out what it is and not just blindly change parts.
Any ideas?
