I have a YZ426 and have recently noticed that there is a light clicking sound coming from, I think, the left side of the engine when I first start out to ride. After riding for a while I don't notice it any more. It only seems to happen when starting in first gear for the first time of the day. Has anyone else experienced this? Should this be cause for alarm or am I just hearing normal stuff.
Clicking sound
Started by Guest_Guest_*, Feb 16 2000 07:53 AM
11 replies to this topic
Posted 16 February 2000 - 07:53 AM
Posted 16 February 2000 - 11:14 AM
I don't think so, why? It sounds like it's around the engine. I'm not completely certain though, it's kind of of hard to ride with my head hanging down near the engine.
Posted 16 February 2000 - 12:17 PM
Exhaust leak or maybe time for a valve adjustment?
When you find it be sure to let us know what it was.
Chris in the Mojave
'98 YZ400F
Chris in the Mojave
'98 YZ400F
Posted 16 February 2000 - 04:53 PM
Sounds like your machine is in need of a valve adjustment. How many hours do you have on the engine?
Quote
Posted 17 February 2000 - 02:47 AM
Yeah Its deffinately your valves, my 1999 wr400 is doing it too. I havent had my valve clearances checked for a while. Going to get it done the same time i get the yz timing
Posted 17 February 2000 - 06:49 AM
My best guess was also that it must be the valves but since it only does it when I first start off, I wasn't sure. I have about 15 hours on it. I guess I better get off my ass and have the valves checked. Obviously this should be done before much riding right? Do most of you check and adjust the valves yourself or take it to the dealer? Thanks for the replies.
Posted 31 July 2005 - 01:05 PM
check exhaust for leeks and valve clearance,s dont really know what you can hear.you probably sorted it by now.
Posted 31 July 2005 - 02:06 PM
I was having the same sound. What I found is that these bikes are notorious for the primary gear to work loose. I pulled by side case (clutch side) and sure enough it was. From what you've described, it sounds exactly the way mine did. Read over this thread and see what you think.
http://www.thumperta...ad.php?t=241749 scroll down to brucer7's post.
Revised: I guess the link is no good anymore.
