I have a 07SM with TT FCR, 3x3 and ordered an Intake Hotcam and was in the mist of swapping it in for the standard SM "IN" cam. But I notice the number of teeth from the paint marked dot's by hotcam to the paint marked arrow on a tooth marked on the Hotcam was different then on the OEM cam tooth count
OEM CAM = left to right CW was 8 teeth and right to left CCW was 9 teeth (arrow points t valley)
HOTCAM = left to right CW was 9 teeth and right to left CCW was 8 teeth (arrow on tooth)
Does this make a difference (correct, or mistake by Hotcam or am i nuts:bonk: )??
While noticing this differance I ended up skipping the chain a bunch of teeth on the EX cam and loosing TDC marking line in the hole.:foul:
My 1st question is --> I can find TDC but does it have to be on the compression up stroke or the exhaust up stroke, I have now both cams out:bonk: if it matters how do I tell which stroke is which??
2nd I noticed when trying to seat the IN cam I couldn’t set the cam, it would rock on the right tappet as if it was high. Prior I took it out tappets and shims one at a time to determine the thickness value off the shims, I then put them back in as they came out before trying to seat the IN cam. Also before breaking any bolts free on the journals I check tappet clearance to be on the low side at right0.004" & left 0.008. I can’t figure out why it won’t seat unless I push I down with my thumb but I think I am just compressing the spring. , any ideas???. (I know that I have rotates the crank shaft a few times in-between to line out he TDC line, in the indicator hole.
3rd does this look correct , 15pins , the IN cam dose not look level based on the dots.
Note: the TDC line always fall naturally to the left as in the pic, is that standard?
