flywheel puller
10 replies to this topic
  • tribalbc
Posted September 12, 2009 - 05:39 AM
I'm looking for a source for a flywheel puller for an 07 WR450.
I'm replacing the cam chain here in a little while so I need to get one.
I can't seem to find one anywhere :busted:
  • ww44wrf450f
Posted September 12, 2009 - 06:40 AM
http://www.thumperta...ad.php?t=793283
  • tribalbc
Posted September 12, 2009 - 06:51 AM
I guess if it comes down to it I'll go down this road but I'd rather just buy a standard $25 puller. Nice and simple.
  • SJMC_DON
Posted September 12, 2009 - 06:52 AM
I got one for an 07' I believe it's a motion pro, my parts guy ordered up for me a couple years ago. I think it's the same one GSXR's use... 33mm I think.
Let me know if you need any details I can provide by looking at the tool. I don't have the original package.
Besides, thats a holder, not a puller...
  • tribalbc
Posted September 12, 2009 - 07:19 AM
Thanks Don.
Found it here, it is a 33mm.
http://www.motionpro...ha/WR_450F/all/
Now hopefully I can get my local shop to order it up for not too much of a mark up :busted:
Have you replaced your cam chain before ?
  • ww44wrf450f
Posted September 12, 2009 - 09:53 AM
http://www.gnarlypar...oducts_id=51767
$14 bucks Canadian?
  • SJMC_DON
Posted September 12, 2009 - 05:44 PM
Thanks Don.
Yeah, when I swapped cams I figured what the hell for 13 bucks, sheeez... the hardest part in my opinion, is re-installing the chain tensioner:banghead:
Have fun... have a good stock of Okeefe's on hand (Is that beer still drunk, drank, guzzled, anymore?)
When I was a kid we used to go fishing at Hi Hium, (Cache Creek, Loon Lake) and at 18 yo you could by beer in Canada... O'keefes was the good stuff back then:banana:
  • tribalbc
Posted September 12, 2009 - 07:00 PM
Well I'm on the same type of program. Replacing my piston with a HC and cams with YZ. Do the cam chain while I'm in there. I got a really good deal on a set of 08 cams so I figured I will first try it with both cams and if the E-start doesn't work than just go with the intake. I'm hoping the 08's will give me some top end and the HC piston some bottom. We'll see.....
Did you fish your new chain in with a string from the bottom or did you just drop it in from the top?
Hi Hium's a cool spot, dual sported through there years ago. I used to drink O'keefes when I was younger too, but I think that was because of the higher alcohol content, 6% :busted:
It's all about the Pilsner now :thumbsup:
  • SJMC_DON
Posted September 12, 2009 - 07:27 PM
I can't remember, I used the method explained to me by EL' MANUEL', I'm sure, and I think that called for dropping it in from the top?
  • tribalbc
Posted September 12, 2009 - 07:42 PM
I can't find anything in the manual on actual cam chain replacement :busted:
I've just read Grayracers explanation.
  • SJMC_DON
Posted September 13, 2009 - 07:27 AM
Probably better than any method explained be El' Manuel'...:busted:
I honestly can't remember how I did it and odd you can'tfdind it in the manual.
Good Luck
