Yoshimura SM exhaust for E model Fit?
8 replies to this topic
  • DeeArrhZee
Posted 11 September 2009 - 08:39 AM
Will a super moto exhaust bolt on 400e model?
  • ROUNDEYEHELMETHEAD
Posted 11 September 2009 - 08:44 AM
it can be made to fit easily. you will need to make a braket for the mid-point or come up with another solution.
i had an s/sm model rs-3 on my e for a while.
old pic & hard to see the mid-point bracket.
http://www.thumperta...achmentid=66417
  • DeeArrhZee
Posted 11 September 2009 - 10:43 AM
Is that it just above the rear master cylinder?
I am a machinist ,so it's not a problem to make a bracket, if that's all it is.
The port at the head diameter is the same? at 1-1/2 inches.(E)
I thought that's where the problem would be.
Thanks for the reply and pic of bike,Very nice.
-K
  • 707drz
Posted 11 September 2009 - 02:01 PM
No other problem except for the mid pipe mount.
  • Goebz
Posted 11 September 2009 - 02:25 PM
the spot where it bolts to the footpeg on the SM is different from the E b/c the E has no passenger pegs. You can buy or make the equivalent of a "Footpeg Eliminator" which is a bracket that moves the mounting point into the right position for the E.
This is along the frame just above the rear master. Search footpeg eliminator and there are several posts.
Some just use some longer bolts and weasel it into place and call it a day.
Posted 12 September 2009 - 05:18 AM
the footpeg eliminator bracket that's sold will not work here.
that bracket was made just to eliminate footpegs on the S/SM models.
here's a pic of the bracket i'm currently using to mount an oem E model exhaust to an S model bike. it's very similar to the other bracket in my 1st pic.
this angle lets you see there is a spacer also. very simple bracket to make.
flat stock with a couple of holes drilled & a cut to size aluminum tube used as the spacer.
  • Goebz
Posted 15 September 2009 - 02:30 PM
AHHH nice work RoundEye, you have fine skills.
This is the one I was thinking of. It will put your mounting hole too high.
Posted 15 September 2009 - 05:44 PM
no, thank you for the compliment goebz.
no skills. just shadetree'd a simple bracket with what i had on hand.
Posted 15 September 2009 - 06:37 PM
i should mention that another key to the system fitting is the band type clamp at the canister.
it allows for adjustment.
