superbike/supermoto rim conversion
13 replies to this topic
  • thatraptorguy
Posted September 09, 2009 - 06:06 PM
im wanting to go the cheap route and use some r6 rims or something like that for my 2007 wr450.....im wondering if this is even possible and if it is what it takes to make it happen.....any info would be more than helpfull!
  • pablo83
Posted September 09, 2009 - 06:11 PM
Unless you happen to find some very cheap rims that happen to fit, I think the cheap route would be to order yourself some 17" wire rims and spoke set and lace them on yourself. It's very time consuming, but it takes no experience. Plus you get to brag that you laced the rims yourself.
  • pablo83
Posted September 09, 2009 - 06:12 PM
BTW, supermotojunkie.com will probably have more information on compatable rims for your bike
  • Gary1scuba
Posted September 09, 2009 - 06:16 PM
Can anyone help me on how to drain and then flush the system of my CRF250X. I have a user manual but it only tells me how to check the cooland level and not how to drain, flush and then refill the coolant system.
Thank you very much.
Gary
  • thatraptorguy
Posted September 09, 2009 - 06:20 PM
Gary
seriously dude????go hijack another thread:moon: .anyways i think i can pick up a set of these rims for close to $400....tell me where i can order hoops hubs n spokes for that much and ill be on it
  • pablo83
Posted September 09, 2009 - 07:04 PM
Gary, it looks like this is your first post. Welcome to ThumperTalk.
First read this:
http://www.thumperta...ad.php?t=467783
Then ask your question here:
http://www.thumperta...splay.php?f=199
Try posting a new thread instead of interrupting another one. :busted:
  • pablo83
Posted September 09, 2009 - 07:22 PM
You're looking at $650 for new rims and spokes. This would require you to use your current hubs.
$400 would be a great price for the wheels. If they fit, get them. If you don't know if they fit then you'll need a lot of measurements from them:
Axle dia - if this isn't the same as yours you might be able to make it work with different sized wheel bearings
Inner swingarm width, wheel offset from centerline - if these aren't the same as your bike you might be able to correct it with new wheel spacers.
Sprocket offset - it's easy to space the sprocket farther out, but requires machine work to set it farther in.
Rotor dia and offset spacing
There's lots to consider with this conversion. It's much easier if you can borrow the wheels to see if they will fit. I fitted a CBR600 rear wheel to my NX650, but most all the measuments between the bikes were identicle, so it wasn't too tough.
Good luck
  • thatraptorguy
Posted September 10, 2009 - 03:11 AM
alright thanks.....any more info anybody??
  • Regalman
Posted September 10, 2009 - 04:47 AM
Several guys have done this mod on DRZ's. You need to find rims that are narrow enough and have single brake rotors.
The GS500 rims were a good start for the DRZ. You need to change out the bearings, create your own spacers and then fab up mounts for the brake calipers.
If you know a guy in a machine shop, you can get out fairly cheaply... if you don't... then your better off going a different route.
  • mrlopez
Posted September 10, 2009 - 08:59 AM
http://www.thumperta...8578&highlight=
check my tread I convert my 00 wr400 to Supermoto
  • justbackitin
Posted September 10, 2009 - 05:26 PM
I put cbr600f3 rims on my 06 wr450. You wont want to go with r6 rims because the rear is simply too wide and both have different axle sizes. The f3 rims have the same axle sizes and the front is pretty much a bolt on mod with different wheel spacers and front brake. The rear is (in my opinion) perfect at 5' wide, although you need to machine the hub area down over an inch. Not everyone has the skill or a lath big enough to spin a wheel that big. Good luck. :busted:
  • thatraptorguy
Posted September 10, 2009 - 05:49 PM
great info man thanks alot......anymore is more than needed:bonk:
  • thatraptorguy
Posted September 10, 2009 - 05:53 PM
can you give me anymore specifics???is the front rotor good enough to run and what you did to make a caliper relocator....how much the back had to machined down for sure and what not....i appreciate the help:thumbsup:
  • mrlopez
Posted September 11, 2009 - 05:59 AM
Sure thing
