Head Work
7 replies to this topic
  • motodiver13
Posted September 09, 2009 - 10:58 AM
I need to clean the head on my '98 WR 400. If I disassemble the valve train do I need to Lap the valves in when I re-assemble?
Also, does anyone know a source for rebuilt cranks?
Thanks
  • wondermuscle
Posted September 10, 2009 - 06:51 AM
Your 400 has steel valves right? If so I 'think' you lapp them but I'm not 100% sure, you will need to cut the valve seats and who ever does that will know.
I ended up just buying a new crank, as getting one rebuilt was only $75 cheaper and was faster and more reliable than getting one rebuilt.
  • motodiver13
Posted September 10, 2009 - 08:14 AM
Thanks- Did you go OEM or aftermarket? If you went aftermarket, where?
  • wondermuscle
Posted September 10, 2009 - 11:38 AM
I went OEM. The aftermarket I believe are simply rebuilt cranks and not newly designed and tooled components. But I'm not certain....
  • pablo83
Posted September 12, 2009 - 08:01 PM
You don't NEED to, but it's very cheap and easy to do and it won't hurt. Also, you don't need the valve seats re-cut unless you are having seating problems. Lapping will help determine if the valves are not seating properly.
  • wondermuscle
Posted September 13, 2009 - 04:14 PM
Only STEEL valves can be lapped. If you lap a Ti valve you will ruin them, it damages the hard Ti coating.
  • JSanfilippo
Posted September 14, 2009 - 12:22 AM
I'd get the seats cut and valves lapped. Why not go for the best possible seal while its apart?
  • motodiver13
Posted September 16, 2009 - 08:04 AM
Thanks for the info guys. I think I am going to part out the bike. I got it cheap and it need a whole new bottom end, crank, bearings, etc...
