Set up 01 426
4 replies to this topic
  • Coolhand
Posted June 21, 2001 - 12:39 AM
Please advise the following:
1. Gearing? 50?
2. Sag? 95MM?
Im running 756s, Tapers with a applied rubber
clamp. All MX ride/race.
Thanks in advance.
Mark
  • Ga426owner1
Posted June 21, 2001 - 05:31 AM
Coolhand, how do you like this compared to your 400? 95-100mm sag is right on. 49 tooth works for most of the tracks you & I ride on. The tighter tracks like "the ridge" a 50 tooth would be better, but you won't be unhappy with either. What is your weight? If over 160lb you will notice harshness in the forks as the oil heats up. I went to .47springs in the forks w/100-95mm oil height. What happened to the Xtrack??????
  • Coolhand
Posted June 21, 2001 - 01:40 PM
GA426:
I have yet to "Wring" out the 26, I will let
you know how it goes. Im 185 naked with a
Med-Rex in my hand. I have MX-Tech fork
and shock mods on the 400 so I may switch
them out. 49? hmmmm...I'll try it.
The bike came with a FMF CDI box with a
bar mounted switch. Going to try that out.
X-track is done due to some crazed horse
loving wacked out 12 pack of milk dud eating
Rosie Odonell watching skank.
  • G-Man
Posted June 22, 2001 - 07:38 AM
"X-track is done due to some crazed horse
Rosie Odonell watching skank."
LOL That's hilarious, sorry to hear bout the track.
On my 01 426 I have done the following with good results:
1) Rubber mounted Tag Bars
2) 50 tooth rear sprocket
3) I set my sag at 4 in.
4) Fork oil height 110mm
So did you buy the bike used, what is up with the switch?
  • Coolhand
Posted June 22, 2001 - 08:21 AM
G-Man,
I got the bike with maybe 30 minn on it.
It came with a HYD clutch and two sets
of 756s, new-in the bag set of 100% tank
stickers, Tag bars and clamps and some
carbon fiber stuff. Will not tell you how
much because it would make you sick....
*less than $4500--------
Why did I switch? well I have loved the 400
but the engine response of the 01 is sweet.
And I was going to buy a 02 but with BNG
and no big changes why?
Hold it wide..
Booth
