WR450F 03 won't kickstart cold
2 replies to this topic
  • mcnuff
Posted September 08, 2009 - 05:25 PM
I have a WR450f 03', the starter motor has always been a problem, but worst still it almost always gives me a hard time trying to kick start it cold, sometimes it will but not often. When it's hot, no worries. It has a new plug and gets good spark. Is this a jetting or valve clearance problem?
  • wondermuscle
Posted September 09, 2009 - 03:33 PM
Tight valves create hard starting at any engine temperature.
What jetting are you running? You might be a bit lean on the pilot jet, you should be running a 48.... I think, check the jetting database.
  • mcnuff
Posted September 14, 2009 - 05:10 PM
Thanks mate, I took the carby off and will check that as i'm not sure
