It's Here...the 2010 YZ450F
1000 replies to this topic
  • Wrfrk
Posted September 08, 2009 - 08:43 AM
#21
Looks amazing...
  • YellowZonker
Posted September 08, 2009 - 08:46 AM
#22
The tank pivots up to service the air filter.
  • mx730md
#23
It looks like you'll have to take the tank and seat off to clean the air filter,:busted:
dont think so. look at the pictures on motocross action mag. rad. plastics are two piece and the filter looks like a flat filter it proable slides in and out like in most cars. not sure if that is a good think since the port is downward and dust and dirt...
any one take notice and see the bike gained 7 lbs? i guess the longer exhaust and fuel pump add most of it
  • DPW
Posted September 08, 2009 - 08:47 AM
#24
more pics>> VitalMX...warning site is slow
#25
A very nice FI system that monitors its self. Thats what iwas hoping for. Unlike the half ass open loop KX, RM, CR 450's
Yamaha states: "Yamaha FI provides optimal air/fuel mixtures in all altitudes and wide range of temperatures for outstanding throttle response."
One could extrapolate this to mean that it's a more sophisticated closed loop, but I don't see an oxygen sensor. More likely just temperature and barometric sensors that bear on the fuel map.
Posted September 08, 2009 - 08:49 AM
#26
No. Why would anyone do that? :thumbsup:
The air box is accessible by removing the upper radiator shrouds.
  • rmracer27
Posted September 08, 2009 - 08:52 AM
#27
Going to be a lot of heat under the seat for sure with the pipe under there like that.
  • kawboy388
#28
Looks much better than the 250F,especially the side panels.
  • digarcia1987
Posted September 08, 2009 - 08:53 AM
#29
very interested in the performance but Im bummed that its so fugly. That frame is hideous. It would have been nice if they applied the looks of the yzf250 to the 450
Posted September 08, 2009 - 08:54 AM
#30
any one take notice and see the bike gained 7 lbs? i guess the longer exhaust added most of it.
That pipe is probably responsible for some of it. But that's another thing: no more stupid, half thought-out "baffle cone" exhaust! :busted:
I wonder what the pipe builders think of this?
Also, with regard to the earlier comment on the effects of the exhaust heat, note that the semi-circular mid pipe section is completely shielded. I don't see a problem.
  • Stu2
Posted September 08, 2009 - 08:55 AM
#31
Ordering one tommorow, this is probably the biggest innovation since disc brakes,mono shock,upside downs and fuel injection.........Well doen Yamaha, just another reason I chose YOU as my brand !!!!!
  • kevman_101
Posted September 08, 2009 - 08:56 AM
#32
Not sure but if you look at the cut away pic on page 1 of the tread, there is a small hole in the header. There doesn`t seem to be anything in it so I could be wrong but that could be the o2 sensor hole.
It`s seems to have all the tools to kick some butt. Hope it does as in almost every sport from MotoGP to Superbike to MX. It looks like it`s a great time to be a Yamaha fan :busted:
  • huffster
Posted September 08, 2009 - 08:58 AM
#33
This bike has no O2 sensor...It's equipped with, basically, the same system as all the others.
Posted September 08, 2009 - 09:04 AM
#34
In the first place, I don't see how you can call it ugly, but that's me. But let me point out again, lots of ugly stuff is very effective; Glock pistols, the M249 SAW, the F-117, Irish Wolfhounds.....
If you want bling, I'd suggest building a chopper. Politely, of course. :busted:
  • bedell99
Posted September 08, 2009 - 09:05 AM
#35
232 lbs dry weight. Not to bad. 245 lbs wet. I'm hoping that is with a full tank of gas.
Erik
  • mx730md
Posted September 08, 2009 - 09:06 AM
#36
i believe that hole is for the resonator like the fmf powerbomb header
#37
Look behind the pipe. The hole leads into a resonator chamber.
  • twenty34
Posted September 08, 2009 - 09:07 AM
#38
http://www.yamaha-mo...209/0/home.aspx
  • Sider_steve
Posted September 08, 2009 - 09:08 AM
#39
The best part is Yamaha kept the the sticker price competitive.
$8090 for the white model and $7990 for the blue model.
And Yamaha has always been first rate with keeping its riders up to speed with any fixes one might need for bugs on new production models.
  • mx730md
#40
or the very first picture you can see it . right about where the carb is on the older bikes
