It's Here...the 2010 YZ450F
1000 replies to this topic
  • Sider_steve
Posted September 10, 2009 - 12:44 PM
Yhea, if Yamaha reals in one of the Better pro's for next year I wouldnt be suprised if they get a AMA championship.
EDIT: Is any one else curious to see what some of the aftermarket exhaust companies come up with? I'm really curious to see how FMF incorporates the Mega bomb and Power bomb into that tornado design.
Yeah makes me wonder who will be riding it next year:banghead:
If bubba stays healthy and the new 450 is at par or better than the competetion, Chad Reed better not make the same wager in SX as he did in the outdoors.
  • honda597
Posted September 10, 2009 - 12:48 PM
Has anyone noticed that the new engine has the exact same bore, stroke and compression raito as the KTM 450sx. It will be very interesting to see how good this motor is, as the KTM has a real good motor.
As for the weight, my 2008 YZ450 weighed 230.78lbs(104.9kg) without fuel but all other fluids included (I had my bike weighed by a race car fabricator on a killer set of scales.(that should be read "very accurate")
  • Luv2crash
Posted September 10, 2009 - 01:44 PM
My local dealer today told me they were getting 10 2010 YZ450's arriving this month. We'll see i guess
  • ProMed
Posted September 10, 2009 - 02:05 PM
On their website Yamaha's claimed "wet weight" for the 2010 is 245 lbs.
Honda's claimed curb weight* on their 09 CRF450R is 234.8 lbs.
*"Includes all standard equipment, required fluids and full tank of fuel—ready to ride"
Links:
http://www.yamaha-mo...09/0/specs.aspx
http://www.vitalmx.c...da-CRF450R,2866
  • jeffboyd47m
Posted September 10, 2009 - 02:50 PM
With the position of the rear shock resevoir, I wonder how tough it will be to service the rear shock. I have alway's done my own oil changes on the shock.
JB
  • Wiz636
Posted September 10, 2009 - 02:52 PM
That's it...I'm switching to Honda. :busted:
  • KAS
Posted September 10, 2009 - 03:15 PM
Honda lies. Always have.
  • ZéPovinho
JB
guess it will be easier sinse you don't have to drill the filling hole, or juglle whith the shock
I think you just have to lay it sideways, bleed the air out, slightly overfill whith oil, and insert the blader... no?
Posted September 10, 2009 - 03:28 PM
Drilling a bleed/fill hole has never been necessary. But the bladder should be charged with 2-5 psi before the shock is bled, so installing it after the oil's in is the wrong approach.
JB
Wouldn't change my method any, as far as I can see. I fill and bleed through the compression adjuster. Something I learned from Dave Johnson.
  • SC_Spode
Posted September 10, 2009 - 04:02 PM
The new shock resembles the one on the 87-88 CR500 with it's reservoir placement.
I have a soft spot for that old blood red 88 model.... *sigh*
:busted:
  • chandler729
Posted September 10, 2009 - 04:42 PM
looks like it would be a bitch changing filters
  • Solid State
Posted September 10, 2009 - 04:54 PM
There are a lot of neat engineering ideas on this new Yamaha if you read the current details. I hope it works out. That said, it has to be the ugliest modern dirt bike I've ever seen. I was unaware Liberace was still alive much less designing for Yamaha!
  • OUTERLIMITS
Posted September 10, 2009 - 05:07 PM
How so? Compared to an enduro bike, maybe a little more time is involved, but how difficult can it actually be, keeping in mind that filters are meant to be changed between motos etc. I'm sure Yamaha went to some lengths to at least make it simple to take off the necessary components to get at the filter. I would be far more concerned with how well the filter seals or how easy it is to check the seal than how quick I can get at it. Having had a 650R Honda, I'm not at all a fan of flat filters though. I have just never gotten the warm and fuzzy that everything is seated properly. Hopefully Yamaha has a good system for this one.
  • Troutman
Posted September 10, 2009 - 05:55 PM
I think its the sickest bike I have ever seen. I just hope it doesn't have all the issues that plague the the first year 09 CRF 450's.
  • pumasforpets
Posted September 10, 2009 - 06:26 PM
its already there, look at teh header.. there's a hole leading to it, its that sort of silver potato shape behind the pipe, so there will not only be room for that, but anything else you want because that entire spot on the bike is now half daylight... no carb, no airbox... the pipe goes thru there like a rollercoaster, there's probably enough room to put your lunch in there :thumbsup::D:D
Holy crap! I need to see someone put a soup cooker mod on that pipe stat!
Sure, it'll add 2 pounds to the bike, but I think having a hot can of soup while your buddies are munching on pbj is well worth it!
:busted:
  • Sider_steve
Posted September 10, 2009 - 06:28 PM
:busted:
I think it will roast a whole chicken ,,half throttle for 2 hours,,season to taste.
  • twenty34
Posted September 10, 2009 - 06:52 PM
At least you know it'll be able to turn. :thumbsup: :banana:
  • ProMed
Posted September 10, 2009 - 06:58 PM
They all have lied for years on their actual weights, I wouldn't trust any of them. As I mentioned earlier, hopefully one of the tests this year will compare actual weights measured at the track.
  • nickeenoo
Posted September 10, 2009 - 07:05 PM
At least you know it'll be able to turn. :busted: :thumbsup:
Does yours turn? After reading your posts on the Honda forum one is inclined to think you don't like the bike as much as you make out on this true blue forum. :banana:
  • OUTERLIMITS
Posted September 10, 2009 - 07:06 PM
:busted:
As crazy as that may sound, I remember way back when Honda came out with the RFVC engines for the XR350/500/600 there was a little cavity on the head or cylinder of one of those bikes that had a little cover that bolted onto it. Not sure what it was for, but I remember the magazines joking that it would be a good place to wrap a small potato in foil for an after-ride baked potato snack. Butter and chives could be kept in the tool pouch.
  • Hot  38 replies
  • Hot  28 replies
  • Hot  47 replies
