Steering stabilizer advice
6 replies to this topic
  • bcs
Posted September 07, 2009 - 11:17 PM
Have a 2006 WR450. tomorrow I'm gonna buy a Scotts stabilizer, a sub mount, new protaper handlebars and cycra probend hand guards. Any disadvantage to this setup?
This is gonna raise my bars at least an inch. Will I have any problems wiht the length of cables or the front brake line?
Last question--in the stock position, the speedo/odo is already hard to see--its kinda low behind the number plate. When I raise the bars, I think this will be worse. Not good for dual sporting. What has anyone done to make it easier to read? Thanks!
  • kskyles
Posted September 08, 2009 - 12:48 PM
you shouldn't have any issues with the brake line or any cables when you raise that handlebars.
  • pablo83
Posted September 09, 2009 - 06:35 PM
I have a GPR sub-mount stabilizer with Zeta ATV High Bend bars. It's the tallest setup I could find, and all the stock cables still work. I use a handlebar mounted GPS for a speedo, but it's very difficult to read while riding.
  • Navaho6
Posted September 10, 2009 - 11:42 AM
Weldable post is better. The bolt-on post on my '06 comes loose on every ride. Very poor design by Scotts, Imo. Uses two tiny 4mm bolts to clamp on.
  • bg10459
Posted September 10, 2009 - 06:10 PM
I have a sub-mount and CR hi bars on my WR. I had to get a +2" throttle cable, but that's it. You could rotate the throttle on the bars so the cables are on the bottom, instead. I've also got a welded post with nary an issue.
  • pablo83
Posted September 10, 2009 - 07:56 PM
I've rotated my throttle cables to make them work.
  • dustdogg
Posted September 11, 2009 - 05:22 PM
I have the BRP Sub Mount w/ Scotts stabilizer and it is well worth the $$$$$$$$. Mine uses the clamp on post and after 3 years it has stayed tight although I did use loctite. I did not have any trouble with the cables or brake lines being too short either.
