wont start on button (wr250)
2 replies to this topic
  • pymn2001
Posted April 06, 2003 - 08:32 AM
hello folks I know this is for the bigger version but a friends 250 dont want to know off the buton its only done about 400mls and he's tried charging the batt .no joy so swopped one from a ktm still no good it just click when button is pressed any ideas you can reach direct on paulsrob@aol.com or do on list cheers tony (finally been out on mine after the thing with the tree and bones incc :thumbsup:edent
  • KiwiThumper
Posted April 06, 2003 - 04:26 PM
Sounds like a bung starter to me. If the batterys good, the connections are good then theres not much else to look for. Try taking the starter off and see if it turns without load. It could be a stuck pinion too thinking about it.
  • HighPlainsWR
Posted April 06, 2003 - 05:01 PM
I assume this is an 03' WR250. Test the starter switch, Iv'e replaced two. The switch closes a circuit, and I finally gave up on stock and installed a stop switch from a late model Yamaha ATV. It will work fine and even plug in to the stock connection behind the front headlight. Other than that I'd disconnect the battery and use an ohm meter to measure if there is any drainage off the poisitve leads (disconect from the battery first ofcourse). I'll bet you find a small drain. If you do, good luck. It's somewhere in the positive wire loom. If not, it's the battery - replace it.
