YOU with the YZ144
37 replies to this topic
  • whips
Posted October 29, 2009 - 11:04 AM
#21
out of interest what gearing are you guys with 144 kits running
im running stock,13/48 but seen people run 14/48 14/50
  • MJP68
Posted October 29, 2009 - 07:30 PM
#22
It depends on the track, Im running a 13/47 right now but I know the engine will easily pull higher gearing for faster tracks.
  • MAD4MX
Posted November 23, 2009 - 02:23 PM
#23
Beware of running the leaner jets in the UK- I wrecked countless pistons and fine wire plugs when I fitted a VHM YZ144 head with a slightly domed Wiseco 58mm piston / FMF Fatty with FMF shorty- The exhaust combo works well with the 144 kit but I do run the one setting richer needle than std. and anything between a 460-500 main in the winter on the sand- Without 98/99 octane fuel she will detonate- be careful , be prepared to check jetting often once out to 144cc
  • qwert321
Posted November 23, 2009 - 09:49 PM
#24
Can someone tell me why in uk they have to run 460-500 main and i use 370 main and could go leaner when it warms up over 20 Celsius/about 70 Fahrenheit?
  • whips
Posted November 24, 2009 - 12:36 AM
#25
im running a athena kit and stock jetting is perfect,410 main,40 pilot,have gone 2 clips leaner on the needle,from 4 to 2,have had it checked but the local tuning guru and he agreed that its perfect,conditions here are 15-25 degrees celcius and 0-100 meters sea level,(in New Zealand)
the tuner also said run 30% race feul with 98 pump gas,(aviation fuel for me as my girlfriend works at a airfield.sweet)
Edited by whips, November 25, 2009 - 10:22 AM.
  • mac132
Posted December 25, 2009 - 03:11 AM
#26
ok guys it crunch time and i need your help :cheers:
i am doing the winter rebuild and now would be the time to do the 144 conversion so what i am asking is
is the conversion worth the cash it going to set me back in the region of £ 700 / £900 uk pounds and a dont want to spend that kind of cash and be disapointed if u know what i mean !
or should a just srend some of the cash on tuning the 125 engine with a pipe v froce and vortex ignition pack ?
help and advice is needed guys :moon:
  • BRM
Posted December 25, 2009 - 04:29 PM
#27
Have a look at Eric Gore's web site. He has some really good deals which will not cost anywhere near that.
  • mac132
Posted December 26, 2009 - 05:10 AM
#28
any one els got an oppinion
  • DMauro
Posted December 26, 2009 - 07:36 AM
#29
i just did an eric gorr yz 144 for my friends son. it was under $500 with pston and gaskets. as far as porting he basiclly just modified the exhaust port. i only got to rie it up and down a field to jet, but i liked it made me want one. the price is good and its basic so you dont run into problems with exotic type motors.
  • mac132
Posted December 26, 2009 - 09:17 AM
#30
update , i have sourced a second hand athena 144 one which uses the new style head gasket kit with 30 mins light use for £200 uk pounds are the athena kits any good ?
  • DMauro
Posted December 26, 2009 - 10:01 AM
#31
do a search i saw some reviews.
  • mac132
Posted December 26, 2009 - 12:58 PM
#32
cheers dmauro interesting readings thanks:thumbsup:
  • mac132
Posted December 31, 2009 - 09:21 AM
#33
well it arrivd today the athena 144 kit , second hand but very light use and wilt all the gaskets and a piston too , will be starting the projct 144 thread after the new year with lots of pics and write ups :moon:
  • MAD4MX
Posted January 03, 2010 - 02:02 PM
#34
We ran an EG144 kit here in the uk , had many problems with detonation once the weather got colder and low altitude tracks, deep sand / wood chip. In the end we were running one step richer needle , used a 500 size main jet on the beach , still didn't 4 stroke !. Found that a FMF Fatty exhaust and FMF silencer worked well on the 144 , except it promoted the detonation. Haven't had experience of the Athena kit , heard some good things, some negative- good luck- We loved the YZ with the 144 kit , got 33 bhp at the back wheel on a dyno , when it was running a bit rich- compared to the dyno testers 125 it had 3-4 bhp more between 6-9000 rpm , same bhp figures at peak though. Just wasn't reliable once I fitted a VHM head , FMF Fatty pipe- approx 3 hrs per piston at best- Using Avgas helped even though the VHM head was supposed to run on Super Unleaded. Good Luck
  • mac132
Posted January 03, 2010 - 02:21 PM
#35
cheers for the info m8 :thumbsup:i am expecting lots of time to be spent on jetting and setting things up the guy who sold me the kit was running jetting all standard except a 480 main so it just a case of trying things out , im just the pilot my good friend at tote motorsport is the 2 stroke wizard :moon:
  • gregiow
Posted January 30, 2010 - 10:43 AM
#36
hi mac 132, im about to do the athena 144 to my 2006 yz let me know how it goes i plan on using my HGS pipe (125cc) v-force 45pilot 470 main 3rd clip and see how it goes hoping to try it in half term (mid feb) let me know if you have any tips thanks greg
  • mac132
Posted February 06, 2010 - 09:58 AM
#37
hi there just finished rebuilding engine and should be fitting it this weekend m8 i am running a doma front pipe bud tail pipe , v force 3 block and will be starting at a 480 main one clip richer and standard pilot, prob be a bit rich but will lean it down if required , i cannot wait to see the results and will post up as soon as its been out cheers :ride:
  • YZ144 GUY
Posted August 03, 2010 - 08:56 PM
#38
Dont be afraid to try smaller main jets. I would put money on the fact that it would pull hard all of the way through the rpm range. I started with a 440 Main and the bike ran fine, but the powerband did not pull very far. I worked my way down to a 390 and the powerband is great. Very dramatic difference that a $5 jet makes. I do run 50/50 race/pump mix.
07 Eric Gorr YZ144
37.5/390
PC Pipe and Shorty
750'
1984/85 YZ250 rebuild project by jvphotog
  • Hot  40 replies
Yz125 won't hold together. by henderson4890
  • Hot  52 replies
YZ-125.. Crank Case drain plug shattered + more issues.. by david.suggs
  • Hot  25 replies
2001 yz250 will only bump start by Dirtshark808
  • Hot  32 replies
Should a 2stroke idle by TTRpaul
  • Hot  45 replies
