Header pipe glowing RED
6 replies to this topic
  • tvrjohn
Posted September 05, 2009 - 02:04 AM
Can anyone advise why my WR450 header exhaust pipe should glow red hot at just over tickover while stationary in a closed garage ?
Could it be tappet clearance issue ?
Also how can you tell if the rear shock needs a gas refill ?
  • beezer
Posted September 05, 2009 - 05:46 AM
If your header pipe is glowing red it means your rear shock is low on gas.
  • byggd
Posted September 05, 2009 - 12:29 PM
You may want to read through this....
  • DieselSJ
Posted September 05, 2009 - 12:44 PM
I thought it was because the muffler bearing needed lubed.
  • ndw2
Posted September 07, 2009 - 12:09 PM
I thought that was the indicator that it was ready to light my cigar
  • bcs
Posted September 07, 2009 - 10:47 PM
Pilot jet is clogged...mixture at idle very lean. Remove float bowl, clean jets, reassemble, ride. (ok, that's what I found the last time the header on my 450 was glowing).
I'll bet it didn't start very easily, and didn't idle well--maybe you had to have the choke ON even though the bike wasn't cold. If so, its definitely a clogged jet.
  • Alternative
Posted September 07, 2009 - 11:03 PM
My header glows red if left idling for more than a minute. My jetting is perfect, it starts easy (1-2 kicks hot or cold), idles well and doesn't bog. If it doesn't glow when riding it and it starts and runs well don't worry about it.
