oil coming out of dip stick hole when checking
6 replies to this topic
  • 183080922
Posted September 02, 2009 - 06:26 PM
ok so i have a 05 yz450f and when i check the oil i let it idle 10-15 secs (like the previous owner said and showed me). i pull the fill plug and undo my dipstick it starts to over flow?? and i know im not over filling it im only puttting one quart in. any ideas?
thanks in advance
  • mayfield171
Posted September 02, 2009 - 06:47 PM
I have an 06 and it has done the same thing. I have never had a problem from it. I let the motor cool down and check again
  • USED YZ426F
Posted September 02, 2009 - 06:50 PM
Are you checking the oil level with the engine running? If you are, shut it off and try checking the oil.
  • Krannie McKranface
Posted September 02, 2009 - 06:53 PM
thanks in advance
Yeah, but how much are you draining out?
  • mxmaddman
Posted September 02, 2009 - 07:30 PM
How long are you waiting after you shut it off?
Posted September 03, 2009 - 06:40 AM
You must drain oil from both the frame AND the crankcase drain, or you will not be removing all of the oil.
The oil cannot be checked while the engine is running.
  • got5steelman
Posted September 03, 2009 - 08:27 AM
Shut the engine off and let it set for a couple minutes, check the stick, if its still coming out it is too full. Go to the "commond threads" there is a link for manuels. It will help you out. I think they are printable also.
  • Hot  50 replies
  • 5 replies
  • Hot  28 replies
