Bark busters on the 01426
4 replies to this topic
  • eBayThumper
Posted June 19, 2001 - 03:41 PM
Hey All,
Is there a trick to getting bark busters on the 01 426? On the throttle side there is a plastic piece (actual throttle mechanism) that goes clear to the end of the bar and there is only a small hole in the end. Do I have to cut it so the bar-end insert can fit into the bar? Have any of you done this?
I appreciate any advice,
J
  • #1_Hit-man
Posted June 19, 2001 - 03:58 PM
Yes, you must cut it out to fit your guards on. Make sure to cut just enough so it does not rub on the end or your throttle will stick. ~Hit-man~
  • teamtoxic
Posted June 19, 2001 - 04:49 PM
Yes, you have to cut out the end piece. I used a graduated drill bit, that made it very easy.
~~~~~YaMaHaFoUrTwOsIx~~~~~
  • eBayThumper
Posted June 19, 2001 - 06:03 PM
Done!
I used my radial arm saw and just zipped the end off. Had to cut the clutch lever just a bit too. Luckily my brake lever is bent just slightly so it cleared fine. Yes, I did move them in on the bar as far as I could first.
Thanks again ;-)
J
  • finglan
Posted June 20, 2001 - 03:34 AM
I took a hax saw and cut the tube just where it begins to wrap over the bar end. It makes a clean cut and you don't have to take the tube off. Make sure the grip is cut back far enough so it won't stick on the bark buster.
  • Hot  36 replies
  • Hot  38 replies
  • Hot  28 replies
  • Hot  30 replies
