right side crankcase drain bolt
4 replies to this topic
  • yz450fcranker
Posted August 30, 2009 - 04:37 PM
ok i did it i over did the right side crankcase drain bolt by one notch i felt it go easy "loosen up" luckily i undid it at the same time checked the threads and cant say that anything went wrong so i threaded just to about where it should be and its fine should i just go on and ride
  • USED YZ426F
Posted August 30, 2009 - 05:15 PM
You might be able to get away with just riding it.
But, if you started to pull the threads out of the case, it is only a matter of time before it leaks. I would take the 10 minutes and fix it right.
A time-sert will work perfectly in that location and give you a permanent repair.
  • yz450fcranker
Posted August 30, 2009 - 05:33 PM
ive looked into timesert but dont know what to buy can you give me a link to the actual kit i need and explain on installation
Posted August 30, 2009 - 06:31 PM
If it's an '06 or later, nobody's going to fix it in 10 minutes.
  • USED YZ426F
Posted August 30, 2009 - 06:56 PM
http://www.timesert.com/
There are some videos showing how to install.
  • On January 15, 2017
  • Hot  38 replies
  • Hot  36 replies
