engine removal help!
6 replies to this topic
  • bakeyz426f
Posted August 28, 2009 - 03:40 PM
if im not mistaken the engine is attached to the swing arm. i think ive removed everthing else except were it attaches to the swing arm. i removed a nut on one side were a bolt of some kind goes through the swing arm. how do i get the bolt out? the over side of the bolt doesnt look like you can wrench on it. or is this not necessary to remove the engine? this is on a 02 yz426f
  • KJ790
Posted August 28, 2009 - 03:56 PM
It's basically an axle like what goes through your wheel. Take a long punch and a hammer and hit it out. You may have a problem if the swingarm bearings have never been greased, as that pivot bolt will seize in there.
  • bakeyz426f
Posted August 28, 2009 - 04:22 PM
that did it thanks man
  • bakeyz426f
Posted August 28, 2009 - 05:20 PM
i have everything removed except a wire going down to the flywheel. i cant get the two screws out of the flywheel area that seem to be holding the wire. im affraid ill strip them. is there a disconect for the wire some where else or does any one know a good way to get screws out that are in real tight?
  • KJ790
Posted August 28, 2009 - 05:30 PM
There should be a plug on the wire you can disconnect.
Posted August 28, 2009 - 06:43 PM
is there a disconect for the wire some where else ?
Up by where the leads meet the main harness behind the steering head. There's a rubber cover over the connector.
  • bakeyz426f
Posted August 29, 2009 - 07:02 AM
i think im going to just remove the fly wheel and that whole assemby the wires are attached to. im buying a new crank, do i need part number 8? the gear drive
http://www.yamahaspo...nd/default.aspx
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
  • Hot  113 replies
