gasket material
2 replies to this topic
  • 96sp00wr
Posted August 27, 2009 - 10:50 PM
I have an IMS 3.1 or so tank on my WR400 and it has worked great but I seem to go through petcock gaskets like crazy. After giving up on the stock IMS jobs I went to a heavy duty tube cut to shape and now the gas has eaten that one! Any ideas of what material to use would be much appreciated.
  • kskyles
Posted August 28, 2009 - 09:29 AM
you might want to stop by an autoparts store. i know that napa carries some generic gasket material in sheets that you can cut to any shape. i can't remember what it is called, but it wasn't very expensive.
  • 96sp00wr
Posted August 29, 2009 - 02:42 PM
OK, I will reply to my own question for future reference. Whoever suggested fuel line was a genius. I used 1/4" fuel Injection hose cut down the middle, flattened out and cut to length. Drilled the 3 holes and is working nicely. Upon inspection using heavy duty inner tube was not so good the gas turned it to soup and it failed......
