Fork Removal
5 replies to this topic
  • ranger85
Posted August 24, 2009 - 03:40 PM
I'm about to change my oil seals tomorrow and I was reading the manual on removing the forks for the service, and it says to remove the handlebar and headlight. To me though, it looks like I should not have to remove either, looks like I can just remove the front wheel, loosen the pinch bolts on the triple clamp and slide the fork tubes out from the bottom, am I correct?
Thanks!
  • maincrash
Posted August 24, 2009 - 03:53 PM
thats all i do
  • SFDemo
Posted August 24, 2009 - 03:57 PM
Yes, it is a more simple than the manual states. Let me know if you have any questions, I just did my WR400 forks a couple of weeks ago.
  • ww44wrf450f
Posted August 25, 2009 - 02:28 AM
http://www.moto-pro....e_alignment.pdf
:ride:
  • PowerBomb
Posted August 25, 2009 - 03:16 PM
It might be hard to loosen the caps unless the tubes are still pinched in the triple clamp.
  • ranger85
Thanks for the help guys, I got the job complete with minimal cussing. I was surprised how simple that was. The videos are great. The suspension actually feels better now. I don't know if its just the fresh oil or if its because I bled them for the very first time(Not knowing you needed to before every ride). When I removed the bleed screws, they almost shot across the shop there was so much pressure. I got the push button bleeders on there now, should work great.
Thanks again! :ride:
