grey wire mod applicable to wr426 and wr400?
7 replies to this topic
  • vfr661
Posted August 24, 2009 - 10:42 AM
Got a quick question: Does the grey wire mod applicable to the 99/00 wr400 and 02 wr426? For those who have made the grey wire mod, did you notice a big difference?
  • 2in2out
Posted August 24, 2009 - 10:54 AM
Made a significant difference. My '02 runs like a raped ape now. Considering the Hotcam with auto-decomp for this winters tear-down and valves.
  • pablo83
Posted August 24, 2009 - 06:49 PM
yes, it applies to those bikes
  • johndeere1
Posted August 25, 2009 - 02:10 PM
It applies and makes a world of difference. I actually hooked up a switch that is sold in WPS for a KTM that allows to connect and disconnect on the fly. My bike had the wire disconnected when i bought and is jetted for it. but it is nice being able to switch it back and forth. I use the wr mode for knarly hill climbs then open it up on yz map for the high speed stuff.
  • PowerBomb
Posted August 25, 2009 - 03:18 PM
Do you think there any harm in switching it back and forth like that?
  • pablo83
Posted August 25, 2009 - 05:21 PM
What advantage does the WR timing give you on gnarly stuff?
  • johndeere1
Posted August 26, 2009 - 07:03 AM
The low end grunt of the WR map. What you are doing is changing the ramp up of the ignition. The YZ has more of a roll on feel and the WR is basically right now torque.
I hooked it up hoping that it would work the way it thought it would. I riding the first time and really couldn't tell the difference but then I did a 53 mile poker run and I could tell it made a huge difference. I had it in WR mode to begin with because some of the trails were pretty bad at the beginning with some new trail section that required a lot tree dodging. Well when i got tired of being ripped back everytime I hit the throttle I switched it to the YZ just to see and that was much nicer. I could roll on it and was not as aggressive at low rpm so it was easier to hold on and control the throttle.
The time it really shined was a 3 foot root in the middle of an up hill that my friend crashed in front of me on so I had to stop and help him. Then i had start on the hill and go up the bank and around it. I tried in YZ and I had to bring the r's up and dump it and almost went over. So I switched it and was able to just let the engine lug and pull me up and around.
  • johndeere1
Posted August 26, 2009 - 07:06 AM
Oh and for the running issue. From what I understand when you do the Grey wire mod you have to jet it for it. I was told you go bigger jets so switching to WR you would be running richer if anything. Which is not as bad as running lean.
I have a Trail tech Vapor on my bike and the engine ran fine and the temp stayed consistent in either mode so defenitly no heating up was a result.
