Sunoco Race Gas?
3 replies to this topic
  • djtroy
Posted August 24, 2009 - 10:12 AM
I live in Florida and I am thinking about running 50/50 race / pump. I can get 93 pump here in Florida.
Should I go with the Sunoco 100 or 104 unleaded or the 110 leaded all about the same price.
I see people saying they mix this 110 with pump gas. How should I expect my Florida jetting to change?
  • MXandy63
Posted August 24, 2009 - 11:28 AM
I don't know about Florida jetting as I'm in California but this weekend I put 1 gallon of VP red 110 to 4 gallons of pump gas mixed 28:1(Yamalube) for my YZ 125 for a long race with alot of hills and wide open pinned sand washes.50/50 might be a little much unless you have alot of motor mods.Try 1 gallon of 110 to 4 gallons pump gas(91 octane here).It turns out to be around 98 octane.Start off minimal and listen to see if the detonation goes away.Too much race gas when not needed actually robs a little power if its not jetted for high octane fuel.I had a little detonation the weekend before the race thats why I elected to put a gallon of VP 110 in there.Detonation dissapeared and the bike ran great.40 pilot stock needle in the stock position and a 420 main on a '04 YZ 125.Elevation was about 1500' with about 90 degrees and low humidity.I'm guessing Florida is a bit different though.
  • djtroy
Posted August 24, 2009 - 12:02 PM
Thanks I will try 1:4 first.
I was also wondering if I should go with the 110 leaded or the unleaded 100 or 104 Sunoco?
  • psylo535
Posted August 24, 2009 - 12:04 PM
I live in florida and run straight sunoco 110 leaded with a compression head
'14 YZ250 Refresh Thread by IamRooster151
  • 13 replies
Yz 85 for my girlfriend? by Matt Gunter
  • Hot  27 replies
is there really a difference in mixing 30:1 vs 32:1 by TTRpaul
  • Hot  35 replies
gray tranny oil by Colby525
  • Hot  45 replies
Quieting down YZ250 engines. by SellYour4Stroke
  • Hot  42 replies
