yz426f part indenifacation and cam inspection
9 replies to this topic
  • bakeyz426f
Posted August 16, 2009 - 09:10 AM
my cam feels rough on the center lobe so i assume i have to replace it. also this part was damaged on my bike and need to know if im able to buy it without buying a whole new cylinder head.
cam
part i couldnt find to buy on oem parts fider. it is included in the cylinder head assmbly but i couldnt find a number on it. has a chip of metal out of it so it needs to be replaced.
Posted August 16, 2009 - 10:56 AM
Your pictures are too far out of focus to be useful in any way.
The cam saddle caps are never sold separately because the caps are bolted to the head when the cam bores are finished. That assures that the bores are truly round. The caps are only available with the head for that reason, and you should never attempt to use one from a different head.
However, the head is repairable. Companies such as Engine Dynamics can redo the cam bores for a surprisingly low cost, and you'll be back in business.
  • bakeyz426f
Posted August 16, 2009 - 11:17 AM
so they can fix this part with the head? is engine dynamics about the same price as millenium. also do i need a new cam or can they repair the center lobe. it feels rough around the top of the center lobe.
Posted August 16, 2009 - 12:16 PM
Replace the cam.
  • bakeyz426f
Posted August 16, 2009 - 03:25 PM
will yhey be able to fix that cam cap and use it because it chipped a little metal of one edge
  • bakeyz426f
Posted August 16, 2009 - 06:28 PM
does my cam cap look repairable. i really dont wont to have to buy another head.
  • bakeyz426f
Posted August 16, 2009 - 07:52 PM
when i replace the crank do i need to get the bearings and gear that arent included in the assembly.
  • USED YZ426F
Posted August 17, 2009 - 05:59 AM
I would think that a descent machine shop would be able to repair the cam cap as well. Add a little aluminum filler material and machine it as necessary. Make sure that you send the cam cap with the head to your repair shop and ask them to look at it also.
  • USED YZ426F
Posted August 17, 2009 - 06:00 AM
Replace the bearings at the same time. It is cheap insurance to guard against a future repair bill.
Posted August 17, 2009 - 08:20 AM
I already told you it is. That little nick is inconsequential unless it's also cracked.
Bearings, yes. If you mean the crankshaft cam drive sprocket, that is cut directly on the left crank axle, and if worn out or damaged, the left side of the crank, or a complete crank, must be purchased. But that also means the new crank comes with it.
  • Hot  50 replies
  • Hot  113 replies
  • Hot  47 replies
  • Hot  38 replies
